100 Octane
Old Mar 27, 2006 | 01:51 PM
Fear's Track 06's Avatar
Fear's Track 06
Default 100 Octane
Have anyone here ran 100 octane in your cars. what are your thoughts of doing this?
Old Mar 27, 2006 | 02:01 PM
breed's Avatar
breed
i do when i go to the track..you can get it from the pump in new jersey.its like 5.99 gal. i never really noticed that much of a difference.
Old Mar 27, 2006 | 02:03 PM
Fear's Track 06
is there any risk of damaging the engine. by the way its $8 here i think.
Old Mar 27, 2006 | 02:39 PM
Mike Wazowski's Avatar
Mike Wazowski
run it all the time, but I am FI also.
Old Mar 27, 2006 | 02:44 PM
_Shift06's Avatar
_Shift06
From your other post, your vehicle is stock with less than 200 miles on the engine. I don't understand why you would want to run race gas...unless you were FI. Stick with premium unleaded...
Old Mar 27, 2006 | 03:33 PM
Fear's Track 06
k, thanks
Old Mar 27, 2006 | 03:50 PM
BobbyRitz's Avatar
BobbyRitz
Actually you can advance timing when using 100 octane + as it is a more efficient fuel. I have UTEC and have had 100 octane maps made. It appeared that my engine didn't respond to advancing the timing by more than 2-3 degrees. Power gains were very minimal.
All of that said, I've ditched 100 octane as a fuel option mainly due to its cost ($5.90) and the results being minimal.
I'd like to try 116 octane in the future, but since it's not readily available, I haven't had a 116 octane map prepared as of yet.
Old Mar 27, 2006 | 04:25 PM
davidf's Avatar
davidf
you will not see ANY benifits from 116 octane uless you are in the 600/700 hp range.
Old Mar 27, 2006 | 04:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
And stay away from the leaded 116 unless you're running test pipes...
Old Mar 27, 2006 | 04:35 PM
BobbyRitz's Avatar
BobbyRitz
I'm running test pipes...and I'm not too concerned with trying to create a 116 octane NA UTEC map. But thanks for the info.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Mattg350z
Oct 2, 2015 06:51 AM
SharX59
Sep 27, 2015 09:23 AM
