Belt Broke
Old Mar 28, 2006 | 05:20 PM
azmark30's Avatar
azmark30
Default Belt Broke
Can someone tell me whats the other belt besides the serpentine?
my serpentine belt is on but theres another belt thats hanging there broke and my check engine soon light is on..
can someone tell me what belt that is..
also if anyone has any sites with pics of this belt or how to install it would be great..
thanks for any help
Old Mar 28, 2006 | 05:26 PM
MustGoFastR's Avatar
MustGoFastR
That's the AC belt.
Old Mar 28, 2006 | 05:31 PM
XtaZee's Avatar
XtaZee
Old Mar 28, 2006 | 05:37 PM
azmark30's Avatar
azmark30
Thanks -
ITs the AC Belt .. Would that casue my check engine soon light to come on?
Old Mar 28, 2006 | 05:41 PM
MustGoFastR
yes.
jakesford's Avatar
jakesford
Hal..., I mean the computer knows everything...
Old Mar 28, 2006 | 05:51 PM
azmark30's Avatar
azmark30
Does anyone have the rest of what XtaZee posted or will Xtazee post it ? I need the part that tells you how to intall the AC belt..
thanks
Old Mar 28, 2006 | 06:02 PM
XtaZee's Avatar
XtaZee
It's all there. It's from the service maual. You can view a copy of the engine section here.-
http://www.myzroadster.no-ip.org/fil...0manual/EM.pdf
The complete service manual is online here (under resources).-
Old Mar 28, 2006 | 06:07 PM
MustGoFastR
Very easy. Just loosen the 14mm bolt in the middle sof both belt tensioners, then release the tension with the 10mm bolts below them, slip off the big belt, install the new AC belt, replace the big belt and retension. You'll need to put it up on ramps or jackstands, remove the lower engine cover and do it from below.
Old Mar 28, 2006 | 06:21 PM
azmark30's Avatar
azmark30
Thank You -
One more question..
Can I drive with this belt off? Will it hurt anything?
I also bought a SC , should I wait till i install the SC to put on the new AC belt?
thanks again guys..
Old Mar 28, 2006 | 06:26 PM
MustGoFastR
Won't hurt anything to drive without it. If you want to wait until the SC install you can. If you need the AC, go ahead and slap it on; it's not a big deal. You'll just need to reset your ECU after you put it back on to clear the code.
Old Mar 28, 2006 | 06:31 PM
XtaZee's Avatar
XtaZee
Yup.-
350Z ECU Resetting Procedures
Please read all instructions and be familiar with them before any attempts.
A stop watch or an analog clock with a second’s needle will be useful.
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
SonnyWu
Nov 24, 2015 08:19 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
A.Font401
North East
Sep 16, 2015 01:39 PM
