06' MREV Question
Old Apr 11, 2006 | 09:29 AM
Hotwire's Avatar
Hotwire
Default 06' MREV Question
I'm looking into buying an 06' 350 base model, and someone with an 03' Z was telling me that the MREV motors arent compatible with alot of mods, including the Greddy TT kit. Any worries i should have with this or should i just go ahead and buy with no worries. My car has to be mod-friendly with no exceptions so this really worried me last night. I've searched on the G35 forums for about a month now and have heard nothing negative with the MREV motors. Thanks in advance.
Old Apr 11, 2006 | 09:31 AM
FastZ33's Avatar
FastZ33
no dont worry. and ur friend is wrong. the revup motors ONLY support TT setup. nothign else............the only parts that i found out that u can not install on the rev up motor r the following......1. cam shafts 2. cam springs. thats all iknow.
Old Apr 11, 2006 | 09:33 AM
pecora55's Avatar
pecora55
Last i heard there is no F/I application for the MREV motors(300hp)...at this moment
Old Apr 11, 2006 | 09:34 AM
pecora55's Avatar
pecora55
FastZ33, where have you heard this? I have found nothing on this yet because everyone has told me there is nothing, but that the companies are working on getting something out soon...Please provide the info because I am looking at this setup possibly...
Old Apr 11, 2006 | 10:15 AM
97supratt's Avatar
97supratt
The only thing you might have to modify is the harness for the engine management. The engine is almost the same so no modifications for any intercooler plumbing or turbo locations and downpipes.
Old Apr 11, 2006 | 12:18 PM
Hotwire's Avatar
Hotwire
What about the other bolt on's available? Still compatible or no?
Old Apr 11, 2006 | 12:39 PM
97supratt's Avatar
97supratt
Yes, intakes, headers, y-pipes, exhausts, the intake cams are fine but the exhaust doesnt fit. It is mostly the same except for internal parts made for high rev; oil pump, valvetrain, etc.
Old Apr 11, 2006 | 12:51 PM
Wholey Smokes's Avatar
Wholey Smokes
I have another thread going in the FI forum about this. It looks like the ECU pinouts are the same for 06 and previous years (maybe with the exception of an extra pin for the exhaust timing.....not sure).
The APS TT and Greddy TT kits are supposed to work fine. The Turbonetics kit, I think, requires some charge pipe modification and I heard that there is a problem running the technosquare reflash that is meant for the kit. From what I gather, you can use a technosquare reflash on an 06 but the TN reflash is not proven to keep an acceptable AF ratio on the revup motors with the TN kit. I've also heard that you can use intake cams meant for the 03-05 motors but the exhaust cams won't work. Don't worry, though. Many companies are working on these problems and new parts should be out this year.
Miaplaya will most likely be able to answer any questions about the TN kit. I believe the 06 version is supposed to be out by summer.
Old Apr 11, 2006 | 01:27 PM
Hotwire's Avatar
Hotwire
Awsome, i was about to not even buy one due to this kid's comments. So i went home and looked at 04-05's and they retain thier value! So basically now im ganna go ahead with the 06' base model.
Btw i appreciate the help. I'll post pics up as soon as i get it.
Old Apr 11, 2006 | 10:50 PM
Nismo 350z's Avatar
Nismo 350z
I know the APS kit works on the Rev-Up. Look at Nitrouz's car. He is making 500rwhp on the stock block. I think the Rev-Up motors are better for FI because they have forged internals already. Also they do better mod for mod with bolt ons. Rev-Up cams are also going to be available soon.. just cant say from who.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
