Disconnecting the battery question ????
Old Apr 15, 2006 | 01:22 AM
350zdriver1's Avatar
350zdriver1
Question Disconnecting the battery question ????
Hey guys, this might sound really stupid, but i wanna be safe than sorry.
you know how the 350z battery is near the top corner and the only way to disconnect the terminals is to stand on the side. if i was to disconnect the battery(both - and +) on the side(touching the metal fenders) would i get shocked ?
the only reason i asked this is because my past cars all had their batteries near the bottom and the front bumper was plastic.
Old Apr 15, 2006 | 02:02 AM
taurran's Avatar
taurran
What are you talking about? Whatever it is, do it and post here with the results. Remember to post pictures and video.
Old Apr 15, 2006 | 05:19 AM
Just make sure that you are properly dressed.
Old Apr 15, 2006 | 05:27 AM
kpiskin's Avatar
kpiskin
Just disconnect negative ground first. That will shut everything off. If you need to take the battery out, take the positive terminal off second. You may see some small sparking but you'll be okay. Just don't touch the metal part of the terminal.
Old Apr 15, 2006 | 01:18 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Correct, disconnect ground first then your hot positive. When reconnecting, reconnect the positive first, and then ground.
You may see a small spark when you reconnect the ground, but don't be alarmed it is normal and won't hurt you. When you get better and faster at playing with the terminals, there will be no spark. The more you shake it around, on and off the terminal while you are screwing it down, the more it will spark/the larger the spark.
So when reconnecting the ground, connect the terminal on the negative post in a swift and smooth fashion and hold it down as you tighten it up. You will be fine!
Old Apr 15, 2006 | 01:21 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
LOL
Old Apr 15, 2006 | 01:29 PM
UrbanTacticZ
Haha that was a pretty good post, I forgot about that
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
issyz
Jul 2, 2017 03:04 PM
