2nd gear redline 03-05 6spd?
Old May 1, 2006 | 03:03 PM
MoJ's Avatar
MoJ
Default 2nd gear redline 03-05 6spd?
At what speed does the 03-05 6spd redline in 2nd gear? 6800 rpms is the redline - right?
Old May 1, 2006 | 03:33 PM
MoJ's Avatar
MoJ
Originally Posted by mc350z
6600
Sorry, should of been more specific - at what MPH does it redline in 2nd?
Old May 1, 2006 | 03:42 PM
NissanZfan's Avatar
NissanZfan
i would say 50 or so...if no one rings in before me when i drive later I will tell ya.
Old May 1, 2006 | 03:46 PM
barthelb's Avatar
barthelb
Master
its the high 50's around 56-58 because in order to do a 0-60 with a g-tech you have to bounce off the rev-limiter or go to 3rd. This is assuming average traction. If you put the automatic 3.3 gears rather than the 3.5 in the manual it will go to about 65mph.
Old May 1, 2006 | 05:54 PM
roast's Avatar
roast
I know 2nd gear in my bone stock 04.5 base goes over 60mph. I think it's somewhere around 62-63mph.
I'm about to go to my girls house so I'll verify it on the way, and report back later.
Old May 1, 2006 | 06:33 PM
PDX_Racer's Avatar
PDX_Racer
Listed 60 MPH in 2nd, 287 HP engine.
64 MPH in 2nd, 300 HP engine. (higher red line, rev limiter)
Old May 1, 2006 | 10:39 PM
roast's Avatar
roast
confirmed... 62mph... probably hit 63 because the digi is delayed but it showed 62 when I hit the revlimiter.
Old May 2, 2006 | 04:41 AM
mikead_99's Avatar
mikead_99
Yup, I think we will all likely see a hair higher than the listed speeds PDX_Racer posted for us. I know on rev-up I hit 65 pretty regularly while still under redline.
Old May 2, 2006 | 05:18 AM
robes's Avatar
robes
According to Road and Trackhttp://www.roadandtrack.com/reviews/..._350z_data.pdf
Redline in:
1st-38 mph
2nd-61
3rd-88
4th-112
5th-142
6th-155 (Electronically Limited)
Old May 2, 2006 | 08:44 AM
barthelb's Avatar
barthelb
Master
hmm i must be way off, or maybe try it not under boost might show different.
Old May 2, 2006 | 08:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
61-62mph @ fuel cut-which on my car was right at redline....
Old May 2, 2006 | 10:38 AM
roast's Avatar
roast
What about aftermarket rims/rubber?? If your tire diameter is smaller than stock that would reduce the top speed for each gear.
Old May 2, 2006 | 11:10 AM
barthelb's Avatar
barthelb
Master
This is true but Im using 285/35's which should put me just about dead stock. So unless the others had larger than 26.8 overall height in their tires, it would be the same.
Old May 2, 2006 | 12:40 PM
roast's Avatar
roast
Edit. I just realized you run 19's not 18's(duh), and in that case my explantion doesn't hold water because your tire diameter is actually larger than my 17's. Your overall tire diameter is 26.85 while mine is 26.25. I believe the stock 18s (245/45/18) are 26.68. You should actually have more top speed in each gear, assuming your final drive is unchanged.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
