350z Timing Belt Question
Old May 22, 2006 | 02:50 PM
rightwinger's Avatar
rightwinger
Default 350z Timing Belt Question
Hi,
I am about to buy a 2003 Nissan 350z with 50k miles. The guy has not changed water pump/timing belt yet. Is this something I need to worry about, and how often do the belts on the 350z last?
Please let me know as soon as possible
Thanks
Tom
Old May 22, 2006 | 02:57 PM
wld350z's Avatar
wld350z
humm does the water pump leak ?
i know of cars with 80,000 miles still same pump
i would worry about it yet
P.S the Z has timing chains no belts
Old May 22, 2006 | 03:00 PM
rightwinger
So, does the timing chain need to be replaced? Sorry, im a huge car newb. I am planning to learn alot from this forum and trial & error.
So any info you guys give me will help alot.
Thanks again
Old May 22, 2006 | 03:20 PM
350ZZack's Avatar
350ZZack
Make sure you check your blinker fluid. That shows signs of wear and tear, then I wouldn't buy the car.
rightwinger
Please help out.
Old May 22, 2006 | 03:29 PM
rightwinger
Thanks ryan for the inciteful comment. :-( Im glad these are the types of responses I will get from this forum.
Old May 22, 2006 | 03:37 PM
Built2shredZ's Avatar
Built2shredZ
I would have to check my manual, but im pretty sure you don't have to replace the timing chain until 100k miles...
Old May 22, 2006 | 06:11 PM
lax91181's Avatar
lax91181
the timing chain never needs to be replaced as it is a chain not a belt. The engine is "tune up" free for the first 100k or so they say.
Old May 22, 2006 | 06:40 PM
ericjackson's Avatar
ericjackson
sorry i glanced at the manual and didnt really see anything about that, can you help me out on where i can read about it?
thanks
Old May 22, 2006 | 06:44 PM
manofsteele2003's Avatar
manofsteele2003
It should say something about in the services portion of the manual. I think it says the timing chain lasts the life of the engine and the water pump should be good until it goes out.
Old May 22, 2006 | 08:04 PM
superman0604's Avatar
superman0604
Well said.
Old May 23, 2006 | 04:05 AM
MustGoFastR's Avatar
MustGoFastR
Just have the belts inspected; they are likely fine, but it won't hurt to replace them; they are cheap. As for timing chain, spark plugs, etc., look at the service schedule in the manual; I belive what they are saying above is true about not having to do anything until over 100k miles. Enjoy the Z and welcome to the forum; just ignore the idiots.
Old May 23, 2006 | 04:22 AM
rightwinger
Must go faster, after hearing the positive and productive responses it changed my view about the forum and I feel much more welcome. I guess there will always be those idiots that have to bring a good thing down.
Thanks guys
Old May 23, 2006 | 04:37 AM
davidf's Avatar
davidf
Enjoy your new Z.
Old May 23, 2006 | 08:05 AM
MeetJoeAsian's Avatar
MeetJoeAsian
timing chain does not need replacing...just when you get your tune up done, they will inspect your chain to see if it needs to be tighten...other than that, the chain should last you a lifetime....
on a lighter note, hey, since you want to learn by "trial and error", can you do me one favor? get your car up to 80 mph, and drop into the first gear, force it in if you have to...I've always wanted to know what kinda reaction the Z will give....
MeetJoeAsian
oh yeah...and take pictures of before, during and after you do it...
Old May 23, 2006 | 08:14 AM
reyes350z's Avatar
reyes350z
drive it till it breaks! then catch the car on fire and and claim the ins. money for a new one.......LOL!!! its a 350z no worries these engines are pretty durable....
Old May 23, 2006 | 08:31 AM
rightwinger
Smile
80 MPH - what a *****.. I will take it to 125 then drop it into first...ill get a video also.
Old May 23, 2006 | 08:42 AM
sq40's Avatar
sq40
In Reverse?
Old May 23, 2006 | 08:51 AM
barthelb's Avatar
barthelb
Master
I changed my belts, drive and AC at 54k miles, but i have the TT Kit so yours should be good unless its just worn pretty good.
