where is your temp needle point when warmedup?
Old May 27, 2006 | 12:43 AM
jsupetran's Avatar
jsupetran
Default where is your temp needle point when warmedup?
I was just wondering cause after my car is warmed up, from 5 mins after start up to an hour later after a long drive, my needle gauge is at about 40%, or 10% below the middle area of the gauge. I was just wondering if my z may have had an aftermarket radiator cap or lower thermostat form the previous owner. Not that I am complaining about his I was just wondering.
Old May 27, 2006 | 12:47 AM
Tenac1ousZ's Avatar
Tenac1ousZ
10% under middle (about 8:30) is like mine.
Old May 27, 2006 | 12:48 AM
gsazabi's Avatar
gsazabi
That sounds about right. I have Nismo radiator cap, and it doesn't
make any difference.
Old May 27, 2006 | 01:03 AM
Mazinger Z's Avatar
Mazinger Z
I have a nismo cap too, it helps with the warmup and cooldown
Old May 27, 2006 | 04:04 AM
Omsin's Avatar
Omsin
I consider it warmed up when my oil pressure drops to around 65 psi.
Old May 27, 2006 | 04:13 AM
teh215's Avatar
teh215
A radiator cap cannot affect that.
Old May 27, 2006 | 07:28 AM
Matas's Avatar
Matas
Yea thats exactly how mine is. It point just a little below the half way point.
Old May 27, 2006 | 09:38 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Ditto
Old May 27, 2006 | 10:21 AM
HighwaySpeed's Avatar
HighwaySpeed
+1
Old May 27, 2006 | 11:35 AM
indokidd01's Avatar
indokidd01
same here
Old May 27, 2006 | 11:53 AM
Mazinger Z's Avatar
Mazinger Z
Well, that's because your is not real nismo, real nismo ones help with warmup, cooldown, and also decreases compression ratio to make it easier when running triple turbonators, and increases octane from 100 to 110 when using diesel fuel, also, it keeps the fuel "down" when your boosting above 36psi...c'mon everyone knows this crap
Old May 27, 2006 | 12:34 PM
KaiserSoze's Avatar
KaiserSoze
Just a little FYI...Temp needles on water cooled cars don't tell you anything other than "cold" "normal" and "overheating". As long as the needle is somewhere in the middle, you're fine. They aren't sensitive enough to tell you if your coolant is 170 or 210 degrees. The reason for this is because the "normal" water temp varies with driving conditions and load. Manufacturers dumbed the needles so that dealerships don't have all sorts of people bringing their cars in because their water temp needle moved a milimeter. The only accurate temperature guages are on air-cooled engines because the temp on those can change very rapidly so you need the actual temp info so you don't fry your engine.
ablaine
Nov 29, 2016 10:13 AM
Alexreyes
Sep 30, 2015 11:30 PM
SharX59
Sep 27, 2015 09:23 AM
