HID Headlights - Care and feeding
Old Feb 13, 2003 | 07:50 AM
AndyB's Avatar
AndyB
Default HID Headlights - Care and feeding
I have never had a car with real HID headlight before so I have some questions.
I have heard that you don't want to turn them on and off too often (ie flashing headlights as a warning). Is that true?
Are the high and low beams seperate lights? In other words, when I toggle from low beams to high beams or back am I abusing the lights?
On my other cars I frequently use the high beams, but I end up flipping back to low beams frequently when another car comes in to view. Will this be "bad" on the Z?
Any and all HID tips appreciated, thus the generic HID title of this thread!
Old Feb 13, 2003 | 08:00 AM
WayneTN's Avatar
WayneTN
Someone correct me if I'm wrong, but I'm 99.99999% positive that the HID's stay on for both high and low beams and you would not be hurting them at all by going from high/low beams. On high beam you can actually see the two additional beams that come on and are more centralized; go back to low beam and they turn off. The HID's are on all the time when you have the headlights on. Otherwise, they would have to cool down and heat back up all the time - not a good thing.
Also, you may see a little fogging inside the clear cover initially, but it will dissipate over time.
WayneTN
Old Feb 13, 2003 | 08:12 AM
westpak's Avatar
westpak
SFZCC
Correct the high beams are not HID, when you turn on the highs then both highs and the low beam HID's are on.
Also correct to avoid turning on and off your HID's as that uses up life of the HID's, so in low light or short needs just turn on parking lights.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
