Whining sound coming from front Help??
Old May 31, 2006 | 05:04 AM
imjdoggie's Avatar
imjdoggie
Default Whining sound coming from front Help??
Hi guys I was hoping for some help here on this matter. I have a whining sound coming from the front right of the motor. I thought it might be the Alternator or water pump. I went to a friends house who has worked on cars in the past and he put a long screwdriver on the alternator and said it doesn't sound like that is what it is. Then he put the screwdriver on the idle pulley I think and it was shaking like a Harley!! He said he thinks I need a new idle pulley, does this sound right has anyone else had this problem??
Thanks for all your help in advance!
Jason
Old May 31, 2006 | 06:36 AM
imjdoggie's Avatar
imjdoggie
bump
Old May 31, 2006 | 06:44 AM
abyss's Avatar
abyss
is it whining at idle or when you hit the gas?
Old May 31, 2006 | 06:58 AM
kelementz's Avatar
kelementz
i have this problem too.. its when i step on the gas.. it usually happens when the car hasnt been started for a long time.... it whines when i step on the gas, but it goes away few minutes later.... i thought it was from my megan y-pipes.. anyone know?
Old May 31, 2006 | 07:28 AM
SBT's Avatar
SBT
i get a sound like that when im cruising on the highway at about 80 or so with light throttle
is that when you get it? this seems to be a normal thing with most Z owners.
Old May 31, 2006 | 07:50 AM
KDW2002's Avatar
KDW2002
I get the same as SBT !!
When I cruise at about 80 and I slightly push the gas pedal, it starts to whine a little, sounds a little like alternator noise but not quite.
Old May 31, 2006 | 08:07 AM
imjdoggie's Avatar
imjdoggie
Mine only happens when I am driving at low speeds I cant really hear it when I am at highway speeds only slow speeds. I dont think it is the tranny because it happens when I have the car in neutral or park too. Like I said earlier my friend put a long screwdriver on the idle pulley I think that's what it was and you could definitely see it was not right it shook like a Harley shakes at idle. He is going to put a new idle pulley on tomorrow so I will let you all know if that fixes my problem.
Jason
Old May 31, 2006 | 08:29 AM
kelementz's Avatar
kelementz
and no its not from my popcharger... just in case people ask if it might be the popcharger.... =)
Old May 31, 2006 | 01:06 PM
imjdoggie's Avatar
imjdoggie
Yea its not a whistle its a whining sound.
Old May 31, 2006 | 03:58 PM
aren21's Avatar
aren21
I got the same problem as you two. Threadstarter: that noise could be caused by many things, just take it to the dealer and have them worry about what it is.
Old May 31, 2006 | 04:40 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
See if George Costanza is trapped under the hood.
Old Jun 1, 2006 | 06:56 AM
imjdoggie's Avatar
imjdoggie
Just got a call from my mechanic saying it was the idle pulley making the noise. It costed me $150 to get it replaced. Hope this helps you guys!
Old Jun 1, 2006 | 09:27 AM
imjdoggie's Avatar
imjdoggie
Just picked her up, purrs like a kitten.
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
AbyteZero
Sep 22, 2015 09:17 AM
