kjr performance
Old Jun 23, 2006 | 01:07 PM
99whis's Avatar
99whis
Default kjr performance
My question is has anyone ordered from this company. Sunday I paypaled them $180 for a pulley and still have no response from them. I have emailed them several times, both nothing. I will go to there page it tells me my order is still processing, but on the receipt it says I will receive my order within 3-5 business days. I will give them a few more days and then maybe trying to get my money back from paypal. I don't know, what do you guys think. I heard nothing bad about this company, thats why I ordered from them. Isn't he a member on here, if so what his member name. Thanks
Old Jun 23, 2006 | 01:13 PM
MrKaira's Avatar
MrKaira
Really MrZ31
yeah, you have nothing to worry about. his forum name is jonathanalboona or some variation of that. i ordered my pulley from them, and got it in a timely manor. Just make sure you put the pulley on tight enough, cause if you don't it will kill your engine, and they won't give you a damn bit of help. If you do a search for kjr pulley i am sure you will pull up many threads about them. overall i think the response to their product has been good, only a couple cases like mine where severe damage was caused.
Old Jun 23, 2006 | 02:19 PM
Ztalker's Avatar
Ztalker
if i'm not mistaken, the crank pulley bolt is torqued to 95ftlb.
Old Jun 23, 2006 | 04:07 PM
DavesZ#3's Avatar
DavesZ#3
Actually, you tighten it to 30-35 ft-lbs then tighten the bolt an additional 60° turn.
Old Jun 23, 2006 | 04:37 PM
NiSmO21z's Avatar
NiSmO21z
Talking Kjr
Yes, I ordered my crank pulley from him. You have nothing to worry about. Great guy. Willing to help you if you need anything. I got my crank pulley quick. My friend ordered from him to and got it fast as well. One of my fav modds.
Old Jun 23, 2006 | 05:53 PM
99whis's Avatar
99whis
For those who put it on yourself, what did you use to check the tension/deflection of the belt. If a certain tool where did you buy it from.
Old Jun 23, 2006 | 07:28 PM
MrKaira's Avatar
MrKaira
Really MrZ31
willing to help you if you need anything? i don't know about that... their pulley killed my engine and it was installed to their directions, which were wrong, and they said they would send me a new pulley, and never did. I had to replace my entire motor because of bent valves, caused by a chip of aluminum sheering off of the back of the pulley and messing up the timing chain, in turn throwing off the time, and destroying the engine.
EDIT: they said they wouldnt cover the engine because they didn't install the pulley themselves.
Old Jun 24, 2006 | 06:03 AM
DavesZ#3's Avatar
DavesZ#3
I could never find a belt tension gauge and the manual method of measuring deflection requires a spring-type scale which I didn't have either.
What I did was to count how many turns of the tension bolts I made for the two idlers when I loosened them. Then once the new pulley was on, I tightened them the same number of turns.
Old Jun 29, 2006 | 09:04 PM
intoxicatedpete's Avatar
intoxicatedpete
I also ordered my pulley over a month ago but i still havent received it from KJR. 99whis have u received your pulley yet? I ordered it 3 days before you on Tuesday 6/20. Any others have trouble receiving their pulleys?
Old Jun 30, 2006 | 01:03 AM
99whis's Avatar
99whis
I still have not got it, he tells me it is on its way.
Old Jun 30, 2006 | 07:48 AM
97supratt's Avatar
97supratt
Belt tension is more about feel if anything, once you tighten it make sure to pressure down on the belt at the longest section between two points, usually the rule of thumb is it can move within 1 inch.
I have a KJR pulley as well that I have to install, good luck with yours.
Old Jun 30, 2006 | 08:39 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I know a lot of people here have ordered from KJR but never any discrepencies. Well in any case, we have the pulleys in stock. Hopefully they will get your order squared away.
Old Jul 1, 2006 | 09:01 AM
JonathanAboona's Avatar
JonathanAboona
99whis and nismo21z should have 15 dollars back in their paypal account for the inconvenience of shipping late.
once again sorry for the mixup
Old Jul 1, 2006 | 10:17 AM
intoxicatedpete
JonathanAbonna
I appreciate the $15 refund I am received but am still curious about the shipping of the pulley. I was told by Jay P. that it was shipped out on Tuesday 6/20. Was there a problem and it wasn't shipped at that time or was the shipment lost?
Old Jul 5, 2006 | 10:35 AM
JonathanAboona
USPS assured me wednesday would be when you would get them. They still haven't given me a sold answer on what exactly went wrong. Please contact me when you get them.
Old Jul 24, 2006 | 09:11 AM
NA&CH's Avatar
NA&CH
Hey Jonathan, any installation instructions? I bought mine when it first came out and never got a chance to install it
Old Jul 24, 2006 | 09:37 AM
JonathanAboona
http://www.kjrperformance.com/docs/K...%20Install.pdf
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
