400whp N/a Z
Old Aug 21, 2006 | 09:36 PM
  #61
AWDBall20's Avatar
AWDBall20
People with money stop going FI and invest in NA. That way poor people like me can reap the benefits once the cost goes down. And how can anyone say 300whp isnt attainable. Why? cause Nismo R-cams dont put you there or because JWT's dont. Maybe if there were more than 2 or three options and people porting their heads along with valve jobs and what nots 300whp would've been easily done by now. But FI is much easier and in the long run cheaper. So to each his own but 400whp will happen just a matter of when, not if.
Old Aug 21, 2006 | 09:48 PM
  #62
Voboy's Avatar
Voboy
Originally Posted by ANXIOUZ
Someone show me a NA 300WHP Z and I'll start my dreams of a 400WHP NA Z. People went fudging nuts when someone here claimed to get 300WHP. In the end they were merely close.
Now we're talking 400WHP? I just don't see it happening for less than several, several , many, many, multitidues of thousands of $ks.
Rickdogg? No engine mods.
Old Aug 21, 2006 | 10:29 PM
  #63
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Rickdogg doesn't have 300.. he's close though.
Old Aug 22, 2006 | 02:51 AM
  #64
ReV2Red's Avatar
ReV2Red
I haz da turbos
Try www.webamuse.co.jp And just look around were you see Z33.
Old Aug 22, 2006 | 09:01 AM
  #65
97supratt's Avatar
97supratt
I think crawford is the closest to 300, they got 29x whp.
Old Aug 22, 2006 | 09:09 AM
  #66
Quamen's Avatar
Quamen
300whp is by no means hard to reach in these engines and the cost of the build could be done for about the price of a supercharger kit. Of course it will be with high compression pistons (possible race gas usage), but the engines are definitly capable of it and 400whp more than likely. It is a matter of money and if you want to run race gas or not.
Old Aug 22, 2006 | 09:45 AM
  #67
ANXIOUZ's Avatar
ANXIOUZ
My point was more "let's see some 300WHP NA Z's before we start looking 100WHP past that." I think both can be done but it's def not common by any means.
I found 1 page and can't read a word...and see no numbers.
Old Aug 22, 2006 | 10:43 AM
  #68
rednezz's Avatar
rednezz
Someone else on this board has actually gone over 300 rwhp but they needed a bump in compression and some cams to do it. I know you can come close to the 300 mark without the higher compression but I don't think you can pass it without sacrificing streetability. Seems like the limiting factor is the intake system.
Originally Posted by Nismo 350z
I dont think its gonna cost 45K just to get 350whp NA. More like 15k same cost as buying, installing, and tuning a FI kit.
For $13,000 you can get a built shortblock with 11.5 CR pistons, custom grind cams, and high flow heads without labor. That would net you over 300+ rwhp.
Old Aug 22, 2006 | 02:46 PM
  #69
97supratt's Avatar
97supratt
Crawford did 29x with bolt on's and experimental cams, they didnt touch the pistons or rods.
Old Aug 23, 2006 | 02:42 AM
  #70
taurran's Avatar
taurran
What most here don't understand is that without increasing displacement, making NA power becomes exponentially more difficult to pull out of a motor the higher you go. With all of the hours spent on R&D to build a vq35 to spec to make over 350 all-motor whp, you will have spent enough to have bought another 350z altogether ($30-40k+). It's not like you're going to log on to a website and buy enough bolt-ons to get you there. This is going to require some extensive custom work and trial and error, which is EXPENSIVE (unless you own your own machine shop and have a lot of free time).
With a forced induction setup, you're completely forgoing this obstacle by compressing more air into the same allotted space within the combustion chamber. You want more power, then just turn up the boost.
Old Aug 23, 2006 | 03:33 AM
  #71
ReV2Red's Avatar
ReV2Red
I haz da turbos
You couldn't have looked too hard. http://www.webamuse.co.jp/new/20050826/350z_0508.html
Go right to the bottom where it says Z33 CPV35
Old Aug 23, 2006 | 07:01 AM
  #72
03zsmith25's Avatar
03zsmith25
if it is ever done, you can bet your *** this setup with include both the turbonator and dual pop chargers with lots of stickers....
Old Aug 23, 2006 | 07:14 AM
  #73
ANXIOUZ's Avatar
ANXIOUZ
Thanks. I believe you...I just get garbage on that site though.
Attached Thumbnails 400whp N/a Z-blah.jpg
Old Aug 23, 2006 | 07:29 AM
  #74
97supratt's Avatar
97supratt
Actually the highest hp amuse offers is 249hp, not whp.
Here is the link to the pdf file.
http://www.webamuse.co.jp/new/20050325/z33.pdf
Old Aug 23, 2006 | 09:37 AM
  #75
AWDBall20's Avatar
AWDBall20
lol
Old Aug 23, 2006 | 11:18 AM
  #76
ReV2Red's Avatar
ReV2Red
I haz da turbos
You mean 349 right? And that's exactly what i said earlier on. 349PS which is not 300 whp, but close. And it is quite old, so they might have improved on that.
Old Aug 23, 2006 | 12:12 PM
  #77
mhoward1's Avatar
mhoward1
With the new 7500 RPM redline, things may change in PEAK HP available
Old Aug 23, 2006 | 12:46 PM
  #78
97supratt's Avatar
97supratt
Early in the morning + me = doesn't work too well
lol
Yes I meant 349.
Old Aug 31, 2006 | 11:42 PM
  #79
Juanito350Z's Avatar
Juanito350Z
OK.. I've made 303whp on the Z back in the Day. All mtor I Had the stock intake, with K&N drop in, had AAM spacer, Headers, Test pipes, Y-Pipe, Exhaust, Jimwolf Wolf clutch and flywheel, Technosquare U1 ECU Flash and some more tunining with SAFC, along with some C16.. about 117 octane, NGK Spark Plugs, **** even threw in the ground wires and hypervoltage wires.. I really dnt remember but i was all about it.. spent like 5G's not worth it guys.. really.. if you crave power just save those 5G's and buy them twins and BTW this was done on a revup..
Old Sep 2, 2006 | 03:23 PM
  #80
Nismo 350z's Avatar
Nismo 350z
I think they meant 400 crank hp NA which would = 300+whp.
