2006 RPMS at certain speeds
Hey guys,
I tried searching, but i totally can't focus right now, its 2:30 in the morning. Here is my question:
What are the speeds at certain rpms in certain gears for a 2006 6mt?
EX:
1st Gear:
2000 rpms - 10mphs
3000 rpms - 20mphs
2nd Gear
2000rpms - 20mphs
And so on. If someone could link me or let me know, I would appreciate it
I just want to see if mine is running high. I am stock and at 900 miles now. Thanks again.
EX:
1st Gear:
2000 rpms - 10mphs
3000 rpms - 20mphs
2nd Gear
2000rpms - 20mphs
All 6mt 350z's as of currently are geared the same. Same gear ratios and same final drive. Tire size is the only potential variable and it's small.
Thanks guys, chineseguy, thats what i was looking for
How much do you say is the most anyone should be off by? 200 rpm, 300 rpm, 500 rpms? I think I am
4th - 40mph 2300 rpms.
5th - 47mph 2000 rpms.
6th - 58mph 2000 rpms.
How much do you say is the most anyone should be off by? 200 rpm, 300 rpm, 500 rpms? I think I am4th - 40mph 2300 rpms.
Performance Nissan
Performance Nissan
here is how to do the math...
i worked out the math in a thread...
I did this for the AT guys....
Ok here are my calculations on the gears:
1st - 3.540
2nd - 2.264
3rd - 1.471
4th - 1.000
5th - 0.834
Stock Tire Size 245/45/18 = Revs Per Mile = 756
FD = 3.3
FD = 3.538
FD = 3.700
FD = 3.917
Formula:
RPM / FD Gear Size / Tire RPM x 60 = Speed in MPH
RPM:
3000 RPM in 4th Gear:
3.3 @ 3000 RPM = 72.15 MPH
3.538 @ 3000 RPM = 67.29 MPH
3.700 @ 3000 RPM = 64.35 MPH
3.917 @ 3000 RPM = 60.78 MPH
3.3 @ 6000 RPM = 144.30 MPH
3.538 @ 6000 RPM = 134.59 MPH
3.700 @ 6000 RPM = 128.70 MPH
3.917 @ 6000 RPM = 121.57 MPH
Forumla for other gears:
RPM / (FD Gear Size x Tranny Gear Size) / Tire RPM x 60 = Speed in MPH
3000 RPM in 5th Gear:
3.3 @ 3000 RPM = 86.51 MPH
3.538 @ 3000 RPM = 80.71 MPH
3.700 @ 3000 RPM = 77.17 MPH
3.917 @ 3000 RPM = 72.90 MPH
3.3 @ 6000 RPM = 173.02 MPH
3.538 @ 6000 RPM = 161.42 MPH
3.700 @ 6000 RPM = 154.35 MPH
3.917 @ 6000 RPM = 144.21 MPH
6200 RPM in 1st Gear:
3.3 @ 6200 RPM = 42.12 MPH
3.538 @ 6200 RPM = 39.30 MPH
3.700 @ 6200 RPM = 37.56 MPH
3.917 @ 6200 RPM = 35.48 MPH
The 3.7 gear set works with any rear end that will work with the 3.5 or 3.9 gear set...
So, basicly all you need is a 3.5 6MT pumpkin w/ VLSD or can be used with any Aftermarket LSD that works with the 3.5 gear set...
THe 3.70 gear set is: $480 for the gear set alone... You will also need the same pinion nut, pinion seal, spacer housing, bearing, etc etc just like with the 3.5 gear set...
to date ive done half a dozen of the 3.7 gear sets into auto's...
1st - 3.540
2nd - 2.264
3rd - 1.471
4th - 1.000
5th - 0.834
FD = 3.3
FD = 3.538
FD = 3.700
FD = 3.917
Formula:
RPM:
Originally Posted by roast
lol I'm still trying to figure out what the issue is here....
Get in your car. Drive. Observe.
Could be...Disconnected the milage and his Speed gauge doesnt work, so he has to judge his speed by the tach....
Could be, but thats against the law im sure he wouldnt do something like that.
I have stock 18s that come with the 2006. There is no issue, I am just curious, lol. I was watching my speed and rpms, and I was just wondering what everyone else gets. only thing i did was that clutch engagement mod. I guess the closest thing to an issue is to see if I have it down to low, and that might increase rpms compared to speed? Does that sound right?
Originally Posted by davidv
2,000rpm? 3,000rpm?
Take the Z for a ride a put the peddle to the floor. Have some fun will ya.
900 miles means its ready for war, step on it a little, then change the oil. And unless your running under or over sized tires your gearing will be identical to other 6MT Z's-LOL the things some people worry about...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Justin100
Nov 29, 2015 03:58 PM
Makes me cry, lol, but it loves to be driven.
