Oil Light Comming On..
Old Jul 12, 2006 | 07:55 AM
JDOUBLE's Avatar
JDOUBLE
Default Oil Light Comming On..
Any ideas what could be wrong? how much $ we are talking? My Z only has 35k on it so i'm a little supprised i'm having problems already. Any help would be appriciated
J
Old Jul 12, 2006 | 07:56 AM
bmac03z's Avatar
bmac03z
You're probably just low on oil. Did you check it? How's the oil pressure?
Old Jul 12, 2006 | 07:58 AM
JDOUBLE's Avatar
JDOUBLE
oil level is good, and pressure is good as well..owners manual says the light doesn't indicate oil level and to have my car towed in for service, which is why I am a little worried..
thanks for the reply
Old Jul 12, 2006 | 08:01 AM
bmac03z's Avatar
bmac03z
Yeah the light is probably for oil pressure. If your low on oil your pressure can drop. Anyone know if the Z has a seperate sending unit for the guage and warning light? If so it could just be a bad sending unit.
Old Jul 12, 2006 | 08:04 AM
JDOUBLE's Avatar
JDOUBLE
also, I use synthetic and it's only been 4k since my last change. only had my Z for 4k miles so not sure if it's normal to loose that much oil that quickly?
Old Jul 12, 2006 | 08:12 AM
bmac03z's Avatar
bmac03z
I use synthetic too and don't have any problem. I have read some people on here having problem with oil consumption..
Old Jul 12, 2006 | 09:04 AM
JDOUBLE's Avatar
JDOUBLE
just checked the oil level and it was bone dry. wtf! had my oil changed 4k ago. i just hit 36450 miles, hopefully they will cover any problems under warrenty
Old Jul 12, 2006 | 09:34 AM
bailey bill's Avatar
bailey bill
Nope. As long as there is enough oil to keep the pump inlet submerged (about 1-1 1/2 qts), it will still make full oil pressure.
Oil pressure develops on the discharge side of the pump. As long as there is enough oil to keep the pump charged, there is no effect on oil pressure.
bill
Old Jul 12, 2006 | 09:37 AM
bmac03z's Avatar
bmac03z
bill
But if it's low enough or you go around a turn the pressure will drop to 0.
Old Jul 12, 2006 | 09:57 AM
03performz's Avatar
03performz
"oil level is good, and pressure is good as well..owners manual says the light doesn't indicate oil level and to have my car towed in for service, which is why I am a little worried.."
Which is it? Do you or don't you have oil?
Old Jul 12, 2006 | 10:19 AM
JDOUBLE's Avatar
JDOUBLE
dont
Old Jul 12, 2006 | 10:34 AM
stein's Avatar
stein
With 36450 miles on her and running it low on oil I highly doubt Nissan is going to cover it unless something broke causing the oil to leak. Myself I'd still take it in to have them once it over and who knows they may cover it.
Afterwards, if it's still running ok that is I would keep a close eye on the oil! Check it every few days to weekly. Chances are some engine life has been lost but how much is hard to tell. Sounds like someone sold you a car (possibly) knowing it was consuming oil.
GL
Old Jul 12, 2006 | 12:41 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
11:58am - Oil
1:04pm - No Oil
LMAO!
Old Jul 12, 2006 | 10:18 PM
yobri's Avatar
yobri
Originally Posted by HighwaySpeed
11:58am - Oil
1:04pm - No Oil
LMAO!
That was pretty funny... and kind of scary at the same time...
I say, checking the dipstick after the car has been sitting for a few hours if you hadn't done so already (maybe it will be at the very low end of the dipstick). Hopefully it wasn't bone dry...
Old Jul 13, 2006 | 07:14 AM
VO...'s Avatar
VO...
Administrator
don't
I think you've just solved your own problem. Check for obvious leaks. If you leaked 4.5 quarts of oil, your definitely gonna see some some oil on the under side of the car. Yyyyyeah..... If there's no oil on the under carriage, then go buy some, add it, and check your levels in a few days. Happy driving....
-VO should get paid for this kind of info-
JjL
East Canada
Jun 12, 2019 03:04 AM
Vigman
Nov 17, 2015 04:34 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
Darkspy
Sep 7, 2015 09:09 PM
