Flashing LED Security Light ?
Old Feb 22, 2003 | 04:56 AM
devaraj's Avatar
devaraj
Default Flashing LED Security Light ?
A few days ago I brought my new 350Z home from the dealer, and I have a question about the red security indicator light on the dashboard. I have the car parked in my garage with the doors closed but unlocked. The red security light flashes constantly - is this the way it is supposed to work? I was under the assumption that it should only flash as a warning when the car is parked and the doors are locked. Will this constant flashing light eventually wear down my battery?
Old Feb 22, 2003 | 05:38 AM
alphared's Avatar
alphared
don't worry about the led draining the battery. It probly draws like 1-2 amp, i'll take 50 yrs to drain your battery.
Old Feb 22, 2003 | 07:54 AM
Jason's Avatar
Jason
The LED in my other car blinked as soon as you turned off the ignition.
I think this is just the way they are designing them nowdays
Old Feb 22, 2003 | 09:34 AM
Omega350Z's Avatar
Omega350Z
Yep its a dummy proof security feature, its there to ward off teh less cunning would-be theifs. In case you forget to lock your doors the light is there to act as though they are locked.
Remember, theifs always go after the easiest targets, and a flashing red light will make them think twice long enough to move on to teh next car. Keeping valuables out of sight is ALSO a good way to make them move on if you have to leave yours outside.
Old Feb 22, 2003 | 11:00 AM
Intrepid's Avatar
Intrepid
The flashing light means that the vehicle immobilization system is active and to warn potential thief's. And the LED may take 1-2 milliamps not amps. Big difference.
Old Feb 22, 2003 | 04:55 PM
WayneTN's Avatar
WayneTN
Also, when you hit the lock button the red light will burn stead while the alarm is setting (20 - 30 seconds) and then start flashing.
Correct on the current flow, Intrepid. Don't know the exact value, but very low. Don't be concerned about a drain on the battery.
WayneTN
Old Feb 22, 2003 | 07:06 PM
alphared's Avatar
alphared
yeah, was thinking milliamps, but typed amps instead (think it was from looking at the amps installs in other posts)
loudtoyz
Apr 6, 2023 04:52 AM
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
