Need help resetting ECU
Old Jul 21, 2006 | 04:38 PM
dduck44's Avatar
dduck44
Default Need help resetting ECU
Yes, I tried the search for about 40 minutes; just moved so I can't find my shop manuel disc. Also went to the Technosquare site. Can someone help me w/the Technosquare link to this info. Thanks.
Old Jul 21, 2006 | 04:45 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I have never personally gottne the techno. way to work. I'm sure it does but it's a pita. Just unplug the battery for overnight, should do it.
Old Jul 21, 2006 | 04:55 PM
Blue_Z's Avatar
Blue_Z
make sure you do it exactly as it says. you'll need a stopwatch.
I've done it plenty of times when my loaner ECU wasn't fully recognized by my car so it would go into "limp mode" every 35 miles.
Here's my summary of the reset instructions from TS's page
1. Turn the key to ACC, start stopwatch at the same exact time
2. At 00:03 seconds press the accel pedal in and out 5 times and stop just before you reach 00:08
3. Do nothing until 00:16, at 00:16 press the accel pedal down.
4. Let go of pedal at 00:26
5. Press again at 00:36
(Check engine light should start blinking from a slow blink to a fast blink by now)
6. Let go at 00:46
7. Press again at 00:56
8. Let go at 01:06
9. Turn off car
10. Restart Car, CEL should be gone/ECU is now reset
Old Jul 21, 2006 | 05:07 PM
roast's Avatar
roast
I've reset mine a few times too. I never needed a stop watch either(although it would help). I illiterately-shorthanded the instructions onto a little piece of paper. The first time I was a little sloppy with my timing and it didnt work but the other times I was a little more methodical and it worked no problem. To me it seems much easier than popping the hood and disconnecting the battery and pumping the brakes yadda yadda. Very easy to turn a key and pump a pedal.
Old Jul 22, 2006 | 09:15 AM
okst8 z's Avatar
okst8 z
So is it possible to mess this process up . . . and the car go into limp mode?
Old Jul 22, 2006 | 09:19 AM
Nexx's Avatar
Nexx
no its not possible to mess it up and no its not hard and no you do not have to exact just close. ive done it at least 3 times.
Old Jul 22, 2006 | 09:47 AM
nothix's Avatar
nothix
why do you need to reset the ECU anyways? did u try to mess with it?
Old Jul 22, 2006 | 01:10 PM
"Z"orilla's Avatar
"Z"orilla
My car has been in the body shop for over a month now with the battery unplugged..................does that count as a reset?
Old Jul 22, 2006 | 01:24 PM
killerlexus's Avatar
killerlexus
Banned for Scamming
here ya buddy, if you're trying to get rid of SES light on the dash.. http://digitalwheelz.com/diy/ECUResetMethods.html
Old Jul 22, 2006 | 01:35 PM
jaminkid's Avatar
jaminkid
I've done mine before when I install my intake and my plenum spacer from Motordyne. Instructions came with it and it was simple to do.
Old Jul 22, 2006 | 01:44 PM
dduck44's Avatar
dduck44
Thanks everyone.
Old Jul 22, 2006 | 01:53 PM
ANXIOUZ's Avatar
ANXIOUZ
I usually just unplug my battery overnight or on the weekend. I don't have the dexterity for the little pedal dance you have to do.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
