3 months with my 350zr 2005 - issues
Old Jul 23, 2006 | 09:26 PM
MyIS300's Avatar
MyIS300
Unhappy 3 months with my 350zr 2005 - issues
2003-2005 NISSAN 350Z; FUEL TANK DIFFICULT TO FILL AT TIMES
http://www.nissanhelp.com/Ownership/.../NTB05-048.htm
2003 – 2005 NISSAN 350Z; CLICKING NOISE FROM REAR AXLES
http://www.nissanhelp.com/Ownership/.../NTB04-065.htm
2003 – 2005 NISSAN 350Z; GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS
http://www.nissanhelp.com/Ownership/.../NTB03-029.htm
Installed my JWT POPCHARGER and the engines seems to running rich, only getting 16mpg... probably need to have them reset my ecu..
Does everyone have these issues and if so how serious are the ones I've listed?
Old Jul 23, 2006 | 09:31 PM
Built2shredZ's Avatar
Built2shredZ
I have a 2004 6MT 350ZR and i've yet to experience any of those problems, but my brother on his 2004 AT 350ZR has had the axle clicking problem and he also needed to have the roof replaced.... but those were the only two problems he ran into
Old Jul 23, 2006 | 09:32 PM
MyIS300's Avatar
MyIS300
the fuel take was today... the car was empty and i could only fill up ~7 gallons... kept on clicking...
Old Jul 23, 2006 | 09:33 PM
MyIS300's Avatar
MyIS300
greese marks have gone down, but I still can see them...
MyIS300's Avatar
MyIS300
what was wrong with his roof?
Old Jul 23, 2006 | 09:34 PM
Built2shredZ
I've read that several other members have had a similar problem, if you fill up while holding the nozzle you might try letting guy once you got the nozzle in and you lock the trigger in place...
Old Jul 23, 2006 | 09:35 PM
highside107's Avatar
highside107
I have a '05 Z with 26k miles and have yet to have the grease mark thing. I know they were a problem on the '03-'04s, but I'm not sure if they're a big problem on the '05s. I have both the 'hard to fill' problem and the 'rear axle noise'. I know there's a fix for the filling up the gas problem, but many Z owners like myself haven't fixed it yet. Actually that problem seems to come and go and I haven't had it in awhile. The rear axle clicking problem is a TSB. I went to the dealer and they literally fixed it in one hour. I paid nothing since it was still under warranty. Other than those minor problems, '05 Zs seem to be problem-free and pretty reliable so far. Except for the cheap paint
Built2shredZ
If you do a search you will find several members have had to replace there tops because of either pin holes appearing or the rear seam starts to come apart. In my brothers case the seam was coming undone.. So far so good on my top..
Old Jul 23, 2006 | 09:37 PM
MyIS300's Avatar
MyIS300
got any pics of these pin holes or rear seam?
Old Jul 23, 2006 | 09:41 PM
MyIS300's Avatar
MyIS300
No luck.. it just keep on clicking.. no matter what amount of pressure i give it...
Old Jul 23, 2006 | 09:43 PM
Built2shredZ
The rear seam is easy to see, just look along the back of the roof where the roof wraps over the rear bar, if the seam is starting to peal up then you need to have it replaced (its covered by warranty)... The pinholes are harder to see.. I don't have any pictures of the pinholes since my top is still good, but I know a few peopel posted pictures of it awhile back... If I find the threads ill send you a link
Try this thread
https://my350z.com/forum/showthread....light=pinholes
Old Jul 23, 2006 | 09:57 PM
roast's Avatar
roast
Those are all very common problems, and minor.
Old Jul 24, 2006 | 07:21 AM
MERK350Z's Avatar
MERK350Z
Default click
click click click damn click every time i shift gear or step on the gas i hear the click dont worry man your not the only one with the click the dealer orderd the parts for me and they are going to fix my issue this week
Old Jul 24, 2006 | 08:05 AM
LODOSS's Avatar
LODOSS
I have newer model 05s and i also have the grease staines.. I told the deal bout it and they said np they'll fix it.. they ended up repalcing the whole window and not the problem..
Old Jul 24, 2006 | 08:48 AM
06Firebase's Avatar
06Firebase
Unhappy
My car had all those issues (and more) under the previous owner.
Fortunately, they were fixed at the dealership. I asked them repeatedly to provide me with a hardcopy of what was fixed. Now I am starting to get the "window problem". They performed the "reset" procedure, and it seems OK after the first week.
Good luck with your '05.
Old Jul 24, 2006 | 09:01 AM
m9999's Avatar
m9999
To have these problems repaired...is it something that we have to pay for, or does Nissan? I have the gas tank problem where it won't fill up past 10 gallons and I've been worried about the cost of fixing it.
Old Jul 24, 2006 | 10:10 AM
UltraYellow350z's Avatar
UltraYellow350z
I have an 2005 and I have the same problems. After the dealer did the grease fix, there is still a little grease residue. They are all not big problems. The fuel thing only occurs occasionally for me so no biggie. Im not about to go waste my time at the dealership trying to get this little things fixed. Don't worry so much about the small things and enjoy the car
Old Jul 24, 2006 | 08:00 PM
Built2shredZ
Its all covered by the warranty
Old Jul 24, 2006 | 10:27 PM
m9999's Avatar
m9999
what if your warranty is up?
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
