Fastest 350z
Old Sep 26, 2006 | 07:16 AM
koco's Avatar
koco
Default Fastest 350z
what model year have the fastest 350z. I know that 06 have 300hp, but weights a lot more then the 03 model?
Is the 03 and 04 pretty much the same, with weight and engine components?
Old Sep 26, 2006 | 07:38 AM
ANXIOUZ's Avatar
ANXIOUZ
My bet would be on an 05 Track model.
Old Sep 26, 2006 | 07:42 AM
BlackZero6's Avatar
BlackZero6
theyre all pretty much the same minus weight....some weigh more than others
in terms of performance.....a non rev up motor could take a rev up off the line...from a the rev up should be able to take a non revup
theres not that much difference in performance between the models..its all what options you want
Old Sep 26, 2006 | 07:55 AM
Jenn350Z's Avatar
Jenn350Z
I know, I know...
This is pretty vague but here it is anyways
2003 Nissan 350z 5.4 14.1
2004 Nissan 350z Roadster 5.7 14.3
2004 Nissan 350Z 5.3 13.77 (M.T. Mar '04)
2005 Nissan 350Z 35th Anniversary Edition 6 Speed 5.8 14.3 (C&D Apr '05)
From: http://www.albeedigital.com/supercou...0-60times.html
Old Sep 26, 2006 | 09:23 AM
geomark's Avatar
geomark
I got this from c&d issue about the z. Any truth to this?
"The 3.5-liter VQ V-6 has always had so much grunt that drivers of manual versions often burn the clutches by overslipping them when pulling away."
Can you burn a clutch quicker by doing this. It seems I overrev sometimes when starting from a red light.
Old Sep 26, 2006 | 09:25 AM
gabez33's Avatar
gabez33
I remember when I weighed my 06 it didnt weigh what nissan said, it weighed alot less....(looking for slip right now)
Old Sep 26, 2006 | 09:33 AM
chimmike's Avatar
chimmike
I have a faster 350z than any year off the factory floor :P
Old Sep 26, 2006 | 09:43 AM
ANXIOUZ's Avatar
ANXIOUZ
I've never heard that statement before. I think they just needed to fill the column with text and made that up.
Old Sep 26, 2006 | 09:58 AM
drifter23's Avatar
drifter23
I have heard the Base models are the lightest is this true....?
FastZ33's Avatar
FastZ33
05 track
Old Sep 26, 2006 | 10:12 AM
chimmike's Avatar
chimmike
Originally Posted by FastZ33
05 track
too heavy.
the Revup models in stock form are actually pretty equivalent to the 287 motor simply due to the lost torque.
IIRC the 03s had the fastest models because they were the lightest.
Old Sep 26, 2006 | 11:23 AM
koco's Avatar
koco
yeah i would think the 03 models too? interesting!
Old Sep 26, 2006 | 12:15 PM
ke0ki2k's Avatar
ke0ki2k
Default hmm
i know for 06's the base is the lightest...has the shortest 60-0 braking of all the models by a few feet actually *surprising since it doesnt have brembos, but the brembos dont fade like my rotors*...as far as speed...theyre pretty much all the same...sept automatic versions are slower than MT models...point is...even if u have the quickest stock 350..there are still tons of heavily modified Z's that will kick your *** :P lol
Old Sep 26, 2006 | 12:27 PM
gabez33's Avatar
gabez33
hahaha +1
Old Sep 26, 2006 | 05:46 PM
Nismo 350z's Avatar
Nismo 350z
03 base. Lightest and fastest. 05 Track weighs more because of the brembos.
Old Sep 26, 2006 | 06:51 PM
Spec_Tacular's Avatar
Spec_Tacular
The Brembo discs are a bit heavier but the calipers are aluminum.
Old Sep 26, 2006 | 07:06 PM
zpak's Avatar
zpak
03-05 Track rims are 8 lbs lighter (18 lbs per wheel vs. ~26 lbs).
Old Sep 26, 2006 | 07:11 PM
zpak's Avatar
zpak
Originally Posted by Jenn350Z
I know, I know...
That 5.3s time belongs to the Track version. See:
http://www.motortrend.com/roadtests/...ssan_350z.html
