Iam E46 BMW guy, thinking of going Z.
Old Oct 7, 2006 | 10:41 AM
  #41
Todd350ZX's Avatar
Todd350ZX
Originally Posted by Exta_Z
Derrate,
Re-read my previous posts and try to comprehend what I wrote...nowhere did I say or even try to get at the point that the Z has a stout trans!..no where! I owned a 300ZX before the 350Z, and even though it had more problems, those problems did not appear at 13k miles and were not "known" issues with the car. Nissan isn't really the JDM Nissan it used to be, 90% of the parts are from Renault...a French car maker who is notorious for making cheap, unreliable, safety hazard cars. Like I said, I agree that the cost of the 350Z is hard to beat, but from what GodSendDeath used to drive to what he will be driving is a pretty poor downgrade if you ask me....just my two cents and experience. I got lucky and was able to resell my Z for $28,500 w/13k miles and two years of ownership....but, will I ever buy a Nissan again, NO PHUCKEN WAY!....absolute garbage! Since your a "structural engineer" and not a "mechanical engineer" you mean to tell me that transmissions in cars are not designed based on load tolerance?...which is also translated to how much stress (strength/pressure) is applied to the actual metal parts in the trans case? Same concept is applied in a turbo motor with forged metals....why do you think a 300ZXTT motor can withstand more HP without shooting a piston out the side of the motors' block? Look at Lamborgihni's....they have N/A V12, yet almost 80% of the parts in the motor are forged....leaving you with a very strong motor to start modding. Nissan did go the cheap route with the Z and thats why it has soooo many problems...yet, what is Mitsubishi, Subaru, Audi, etc...doing (that Nissan can't) by creating these potent and very reliable sportscars?
You said Mitsubishi? Hahahaha... Reliable?
Old Oct 7, 2006 | 10:42 AM
  #42
Todd350ZX's Avatar
Todd350ZX
Derrate,
You said Mitsubishi? Hahahaha... Reliable? I can think of the Eclipse and 3000GT/Dodge Stealth.
Old Oct 7, 2006 | 05:57 PM
  #43
Exta_Z's Avatar
Exta_Z
^sorry, I should have been a little bit more clear...i figure when I say names like Mitsubishi, Subaru, etc... you would only think of EVO's and STI's. Yeah the "other" mitsubishi's (the ones really made by Chrysler) are crap...but the EVO and the true JDM Mitsubishi's are exceptional cars!
Old Oct 7, 2006 | 07:08 PM
  #44
Diesel350's Avatar
Diesel350
Definitely go with the Revup 06 motor. Most reliable Z and the revup engine handles boost on a stock block better than the 287 motor.
Old Oct 8, 2006 | 01:09 AM
  #45
Derratte's Avatar
Derratte
Derrate,
90 percent of Nissan parts are not from Renault. I have no idea where you got this from. Parts sharing between the two is still minimal.
Transmissions ARE based on "load tolerance", but more specifically, stress resistance. I never said that they weren't.
Also, strength is not (stress/pressure) as you stated. Strength is simply measured by a material's relationship between stress (load/area) and strain (deformation under load). So, to design a strong transmission, you want gear sets that can withstand lots of load over a given area, with minimal strain displacement (deformation). But this is getting off topic here....
I agree with you that the VQ35DE is not as strong as some of Nissans other motors in the past, such as the VG30DE and the RB26DETT. However, if you are not adding forced induction to the VQ, then whats the difference? The VQ is strong enough for its intended application. Just because the VQ cant handle 1000 hp on the stock block doesn't mean that the engine is somehow inferior. Nissan engineers decided to go for weight savings with the VQ in the Z, and this improved the handling and weight distribution. They *could* have gone with some cast iron block VQ thats super stong and can handle lots of boost, but then the car would likely have weighed 100 pounds more than what it allready is. And trust me, the last thing the Z needs to do is gain any more weight.
I understand that cars like the M3 may demonstrate higher levels of engineering prownes than the Z, but thats why those other cars cost so much more. The STI and Evo may have super duper motors, but the cars themselves leave a lot to be desired in the build quality department, esp in the interior and body panel gapping.
And finally, I dont know what your deal with the Lambo is, but making the argument that a 200,000 dollar Italian exotic uses all forged internals, and therefore the 30,000 dollar Z crap because it only uses a few forged internal parts is pointless.
Have you noticed that S2000 motors do not take to turboing very well either? Both the S2000 and Rev-Up 350Z make use of high compression lightweight motors that are designed to be NA. Bolting on a turbo kit and wondering why the engine is not reliable and calling the WHOLE car crap is nonsensical. The VQ35DE was never meant to be a turbo motor, and thats what Nissan intended. The reason the Evo and STI are so stout is becasue they were designed to be turbo motors from the start! Of course they are going to be stout.
If you think your Z was somehow "crap" just becasue the VQ cant handle some moster turbo kit you wanted to put on, then I rest my case. If the VQ was intended to be a turbo motor, then Im pretty sure you would have seen the stronger internals, and stronger block, most likely cast iron. Nobody's VQ35DE motors are blowing up in their Z's, so I dont really see why you think the motor is so unreliable, or so weak, or so inferior.
Likely the new VQ35HR is going to provide a stronger block (Its intended to be a turbo motor -> GT-R) and stronger internals to handle the extra power demands. And Im willing to bet we will see a new transmission design as well.
Nissan is capible of producing cars that rival or beat the best from Germany. Just look at the new M45. It beat out BMW and Mercedes and Lexus in the recent issue of Car and Driver.
Old Oct 8, 2006 | 06:53 AM
  #46
GodSendsDeath's Avatar
GodSendsDeath
So do you guys recomend that i get GR motor insted.
Old Oct 8, 2006 | 07:29 AM
  #47
Diesel350's Avatar
Diesel350
You mean HR motor? Yea it's gonna be a great motor but did you see what the new hood for the 07 looks like? Not pleasant in my opinion.
Old Oct 8, 2006 | 09:15 AM
  #48
FLZ_Boy's Avatar
FLZ_Boy
Ummmm, that hump is rather...........
Old Oct 8, 2006 | 03:41 PM
  #49
Derratte's Avatar
Derratte
Eww... Thats the hood of the 07' ??? Ugh, it looks like they coulden't fit the new HR motor in there so they just added the hump. It kinda ruins the smooth lines of the Z.
Old Oct 8, 2006 | 03:55 PM
  #50
GodSendsDeath
Thanks guys, honestly i like the hood. Hmm is there any place i could read up on the motor. Thanks agian.
Old Oct 8, 2006 | 05:14 PM
  #51
Spec_Tacular's Avatar
Spec_Tacular
There are several threads on the new HR motor.
Obadabot
Jun 18, 2023 11:31 PM
