New guy here need some questions answered...thanks
Old Oct 12, 2006 | 10:24 AM
Mast3rShak3's Avatar
Mast3rShak3
Default New guy here need some questions answered...thanks
I have an 06 z i shift at about 2000k rpm is this cool? Im a casual driver nothing fancy.
My breaking method involves braking on (x) gear it was in until im almost at a stop and poping it in neutral. Any thoughts?
Im having trouble shifting into those early gears 1 and 2. Its kinda choppy/jerky whatever you call it. Any suggestions/tips?
Also when is it necessary to downshift and whats a proper way of doing it?
my final thing is about reverse what do you guys do when going in reverse and prallalel parking and stuff.
thanks for you help guys. Sorry if i posted in wrong forum section.
Old Oct 12, 2006 | 10:29 AM
VO...'s Avatar
VO...
Administrator
ibftl.
Old Oct 12, 2006 | 10:30 AM
savvy's Avatar
savvy
2k shift is fine, i normally shift around 3k daily driving and trash the hell out of the gears on occasion.
for less jerk between 1st and 2nd try letting the clutch out a bit slower
your way of braking is fine, i normally downshift to make braking easier but its been long debated which is better for you car egine braking vs using only brakes
alot of people when downshift will rev match, basically tap the throttle in neutral to up the rpm's then enter your lower gear. This will do less wear on the syncro's
Basically just learn what speeds will put you at what rpm in each gear. Having this knowledge will help you know what gear to downshift to in order to get the most speed
Old Oct 12, 2006 | 10:40 AM
Welcome.
Give yourself time to learn how to drive a manual transmission. This is not rocket science. When you have, say, 10,000 miles on the car, return and ask for comments. Until then have fun learning.
Old Oct 12, 2006 | 11:23 AM
Mast3rShak3
How do you guys use the reverse gear for parking and stuff?
Old Oct 12, 2006 | 11:26 AM
OCZTrack's Avatar
OCZTrack
I use it to go backwards...what about you?
Old Oct 12, 2006 | 11:27 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Tell us how you use it and we'll tell you what you're doing wrong
Old Oct 12, 2006 | 11:29 AM
Are you telling me that the car goes backwards!
Old Oct 12, 2006 | 12:21 PM
Mast3rShak3
Well i pop in the clutch put it in reverse and release slowly. I push the gas a inty bit but it seems like the it goes too fast and if go to slowly it wants to stall. Kinda difficult specially in small parking zones.
Old Oct 12, 2006 | 12:30 PM
35TH ANY's Avatar
35TH ANY
Shifting a MT rev up @ 2K is rediculous. 4K is about right for normal driving except the 5th to 6th shift.
Old Oct 12, 2006 | 12:45 PM
ouch1011's Avatar
ouch1011
Based on the fact that the VQ has pretty good low end power, shifting around 2500-3000rpm should be fine for daily driving. Might help a bit with the jerking in the lower gears, too.
When in reverse, unless you are really flying in reverse, you really don't need to let the clutch out all the way, just let it out enough to get moving then push it back in.
Old Oct 12, 2006 | 01:48 PM
Mazinger Z's Avatar
Mazinger Z
Ahha...damn some of you guys are really brutal...
Old Oct 12, 2006 | 02:40 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Sounds like you just need practice in reverse. Let clutch out slowly with very little, if any, gas in tight situations.
Old Oct 12, 2006 | 02:47 PM
tropicalypso's Avatar
tropicalypso
5k clutch drop in reverse ftw
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
