Service Engine Soon? Anyone?
Old Mar 25, 2003 | 11:30 AM
TriX's Avatar
TriX
Post Service Engine Soon? Anyone?
Question if this happend to anyone.
I just got the car and its got about 645 miles on it. Today driving to work the Service Engine Soon light came on.
Now I didn't have a chance to mess with it. But I looked at the manual it says to check the gas cap? I was under the impression that Service Engine soon light has to deal with actual engine more then emission or gas. Can anyone shed some light?
Should I go to a dealer?
Old Mar 25, 2003 | 11:57 AM
Turcoupe's Avatar
Turcoupe
It is 99.99% likely a feul pressurization error that tripped the SES light. Mine went off at 900 miles after I got a XM radio unit installed. Try reseating your gas cap and see if it goes out by itself after a few trips, otherwisae go to the dealer and they will reset it in less than 30 minutes. Don't worry though, as long as the SES light is on steady, the ECU thinks it is a fuel pressure problem. NOW if it starts to blink on you, you need to definitely go to the dealership asap. Hope that helps...
Old Mar 25, 2003 | 02:43 PM
TriX's Avatar
TriX
Thanks yeah kept playing with the gas cap today but still nothing. I will drive it tomorrow if it doesn't change I will take it to the dealer. Thanks for the help.
Old Mar 28, 2003 | 08:49 AM
daking350's Avatar
daking350
Exclamation service engine soon light
I just installed an Injen cold air intake and several hours later the service engine soon light came on...any advice??
Old Mar 28, 2003 | 09:11 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Default Re: service engine soon light
Did you unhook the negative terminal on your battery to let the ECU reset?
Old Mar 28, 2003 | 10:36 AM
Electro Z's Avatar
Electro Z
Default Just got back from service
Has the SES light come on on wednesday.
Went to dealership today for LOF.
Had them check it. I was reporting a leak.
No leak found. Expected it to be the gas cap.
Possible the loop holding the cap to car might have gotten under the edge of the seal. It has been reseated and the light reset.
Will let you know if it returns.
Was told not to worry unless it flashes.
EZ
Old Mar 28, 2003 | 11:26 AM
Vlad's Avatar
Vlad
99% Gas cap
Had it many times on many cars and most of it you just tighten the gas cap, and it'll went away after day or two.
Once it was an Oxigen Sensor mulfunction on my Mers
Old Mar 28, 2003 | 11:53 AM
daking350's Avatar
daking350
Default srvice engine soon light
I unhooked the positive wire for about 1/2 hour but the light still stays on..why the negative terminal??
Old Mar 28, 2003 | 12:00 PM
350zSpeedRacer
Default Re: srvice engine soon light
Actually, I'm not sure. That's just always the one I was told to unhook and the one I always saw my dad unhook at the track. Sorry I'm not more help.
Old Mar 28, 2003 | 12:01 PM
Jumpman--Z's Avatar
Jumpman--Z
My light came on Thursday last week. After I reading numerous posts on this forum, I realized that my gas cap was not tight enough, I only had it tightened enough to click once. I tightened it to six clicks. It stayed on for quite a while, but on Wednesday, I noticed it has finally gone off. It probably would have went off sooner, but I only drove to car to school and back on those days, and I didn't go anywhere during the weekend. Before you think about going to the dealer, just drive it for a couple more days.
Old Mar 28, 2003 | 09:46 PM
rodH's Avatar
rodH
I got mine with the light on from the dealer, they ran the codes as a O2 sensor problem, they didn't have the part-cleared the code and ordered the part, I get it fixed on tues (btw, the code re-appeared about 10 miles after I left the dealer)
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
