driving long distance
Old Dec 22, 2006 | 07:23 AM
furiousZ's Avatar
furiousZ
That's the first time I heard a PSI reader warning there is too much PSI in the tires. Nissan is amazing!
Old Dec 24, 2006 | 04:13 PM
chilton00's Avatar
chilton00
Originally Posted by davidv
You can risk your life if you want but don’t blame it on me if all the tires explode and you get charred black in a ball of flames.
N2 is a perfedctly safe inert gas for tires. It could however cause your tire man to pass out if he inhales to much while removing the tire!
Old Dec 25, 2006 | 06:55 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally Posted by sean1967
are you sure, I had a light but no pressure gauge...so I put some air in to tide me over, the light stayed on....when I got home and checked it was over serviced...I let air out and light went away. But I haven't checked the documentation....anyway, is there a schematic of the system...we should be able to find a jumper wire that will stop the light from comming on for the OP
If you had no pressure gauge then the system was not reading a sensor(s)
There is a receiver and 4 sensors (one in each tire not in the spare)...
Old Dec 25, 2006 | 06:57 PM
widebody350's Avatar
widebody350
I get it on long drives too. If you shut the car off it should go away.
Old Dec 25, 2006 | 06:59 PM
dozzer1b's Avatar
dozzer1b
mine goes on as well........its ok tho......its safe....just because of aftermarket rims!!
Obadabot
Jun 18, 2023 11:31 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
