Another thread about TCS and VDC (but different)
The already active thread “Traction Control” is very good reading. Lot's of good information there.
I have another question about VDC. I need to preface the discussion with this information: My only experience on this question is with 2003 and 2004 350Z’s. I do not know if this is applicable to 2005-2006 350Z’s since I did not evaluate these models.
Discussion: The first Z I drove was a 2003 Enthusiast model (this configuration had TLC but not VDC), and I was impressed. It was a great car with a great engine and suspension. My only criticism was the slow drop in RPMs (engine-hanging) while shifting. Otherwise, it was perfect for me.
A few months later I drove a 2003 Z Performance model (that is equipped with VDC). There was a very noticeable difference in the power-assisted equipment (clutch, brakes, and steering) on the Performance model with VDC. The clutch, brakes, and steering on the VDC equipped Performance model were much lighter and felt a whole lot better than on the TLC equipped Enthusiast model. I pointed this out to the dealer who told me I was seeing ghosts (same car with nearly same equipment, should be no difference in the power assisted equipment). Then I took a 2003 Track model (which also has VDC) for a test drive. Same thing: Similar to the Performance model and a lighter feel on the brakes, clutch, and power steering than the Enthusiast model. Thinking the Enthusiast model I was driving was an aberration (suffering from heavy-feeling power assisted equipment), I did a test drive on a different Enthusiast. The newly tested Enthusiast model was exactly like the Enthusiast I was driving (with the same feel of the power-assisted equipment that was not as smooth and light as the VDC equipped Performance model and Track model).
So you know what I did. I got a Performance model. Since then I have had the opportunity to drive a couple of other 2003 Enthusiast models, and the same is true: Power-assisted equipment is not as light and pleasant as on my Performance model.
What’s going on here? Do VDC equipped-models have a higher hydraulic boost? Are the more expensive models different? I have no idea. Again, my comparison is only on 2003 models. I wonder if the same is true for 2005-2006 models. --Spike
Originally Posted by HyperSprite
No
... Just kidding --Spike...And thanks for bumping
performance model 18" wheels = lower sidewall tires, same as track model. better steering feel, less body roll that a touring model with 17" wheels and taller sidewalls. either way the models are very similar.
I have a performanc model. The 18's vs. 17's sounds like a good explaination, but I did notice a difference compared to Base and Ethus. Models. Only thing that I find is that VDC inhibit Horses. I dynoed my car stock in Texas. Mustang Dyno, 91 Octane, 4,000 Feet ASL. 229 was my number. I took of the VDC in the next run and I got 236. I'm not sure why but it happend. On top of that when Taking off from a stop the car boggs if you gun it. VDC doing it's job stopping you from peeling out. So the car feels a little slower if I'm running with VDC on. I turn it off and it feels a bit stronger.
Tochigi_236
Sep 27, 2015 03:40 PM
