Changing the oil of your 305z
Old Jan 10, 2007 | 11:07 AM
dj_saki's Avatar
dj_saki
Default Changing the oil of your 350z
Hey guys, do you have any advice for what synthetic brand of oil to use in your 350z and where I might find a DIY about changing the oil in a 350z?
Thanks.
Saki
Old Jan 10, 2007 | 11:14 AM
JasonZ-YA's Avatar
JasonZ-YA
well, i dont know about a 305z? but on the 350z its quite easy with ramps, and a few tools.
u should be able to find more info on this.....
-j
Old Jan 10, 2007 | 11:17 AM
JasonZ-YA's Avatar
JasonZ-YA
oh ya on synthetics.....everybody will argue one over another! i would cheeck w/ a local shop on what they recommeend due to temps.
where im at in south tx its hot 95% of the time so i choose my lubes accordingly....
-j
Old Jan 10, 2007 | 11:34 AM
6894kevin's Avatar
6894kevin
Easy.
drive the car to warm up the oil
Drive car up on to ramps
Open hood
Pull off oil cap
Crawl under it
Find the oil pan
Locate the oil plug
Undo the oil plug
Drain all the oil from pan
Unscrew oil filter
Lube new filter with oil
Screw new filter in
Screw oil plug back into pan
Fill carr with oil
Put oil cap back on
Close hood
drive off ramps
Done
Check to make sure there is no oil under the car to insure you tightened the filter and plug
Cheers
Kevin
Old Jan 10, 2007 | 12:11 PM
Swiffer's Avatar
Swiffer
Sythetic:
https://my350z.com/forum/search.php?searchid=2535037
Changing:
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/25892-oil-change-101-what-you-need.html
Old Jan 10, 2007 | 12:14 PM
One more best oil thread and I promised members that I would kill myself. This is goodbye. I love you guys.
Old Jan 10, 2007 | 12:15 PM
SargentZ's Avatar
SargentZ
Do you have to use ramps or will a regular jack work? Had a bad experience with ramps in the past.
Old Jan 10, 2007 | 12:19 PM
6894kevin's Avatar
6894kevin
I believe you could use the jack, but i think the Z uses special plates to use the stands. And be carefull to put the jack in the right place or you will f up you floor boards.
Old Jan 10, 2007 | 12:36 PM
PerfZ's Avatar
PerfZ
Floor jack and jackstands work for me. And pull the big "shield" out from underneath - PITA to remove/install the 15 bolts but much easier to get to the filter and drain plug without making a mess. Amsoil is my choice (sorry davidv)
Old Jan 10, 2007 | 12:46 PM
THE TECH's Avatar
THE TECH
If you have to ask how to do an oil change, I don't think you should be doing it.
Old Jan 10, 2007 | 12:50 PM
JasonZ-YA's Avatar
JasonZ-YA
+1
Old Jan 10, 2007 | 12:51 PM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
I use aunt jemima pancake syrup in my delorian.
Old Jan 10, 2007 | 12:53 PM
ct350z's Avatar
ct350z
lmfao....dont do it david
DROPPEDIT2WCE
good bye dave, let us know how the pit beef is in hell, lots of flames probably pretty good. also let us know if there really are cookies and no milk like that old commercial on tv
Old Jan 10, 2007 | 01:25 PM
HighwaySpeed's Avatar
HighwaySpeed
Exclamation
Search
Old Jan 10, 2007 | 01:28 PM
PerfZ's Avatar
PerfZ
Hey, everyone has to start somewhere and an oil change is a good place to do it. As long as you put the drain plug back in, only hand tighten the filter, and make sure you remember to re-fill the oil (4.5 quarts) it's pretty hard to screw it up. Well, I guess the car could fall on you, but that won't hurt the car too badly
Old Jan 10, 2007 | 01:31 PM
daz311x's Avatar
daz311x
what happened to your other .45 liters?
Old Jan 11, 2007 | 08:43 AM
dj_saki's Avatar
dj_saki
I just wanted to know if there was any advice or suggestions that any of you had in changing the oil. I've changed the oil in my car before (not my Z). I have the service manual and found a good pic on http://www.*********.com/zwiki/Service:Index for where to put the jack stands. Thanks for the humorous advice :-)
Cheers,
Saki
Old Jan 11, 2007 | 09:35 AM
DaveZ06's Avatar
DaveZ06
Good you live in LA. I think most people would agree and say Mobil 1 synthetic but you should use synthetic in the summer.. or atleast thats what i think you should do
Old Jan 11, 2007 | 09:53 AM
ericjackson's Avatar
ericjackson
thats half a quart low buddy
