Shifting from 1st-2nd
Old Jan 25, 2007 | 03:47 PM
Zya123's Avatar
Zya123
Default Shifting from 1st-2nd
When i shift from 1st to 2nd gear i can not do it smoothly unless i let the RPM's drop to like 2000, what am i doing wrong?
Old Jan 25, 2007 | 03:51 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Letting out the clutch too fast while not hitting the gas fast enough to catch the RPM drop will cause you to jurk into gear. Does your "slip" light come on or tires chirp alot? Ease off the clutch while slightly giving it some gas. Unless you're trying to race rice boy to the next light, that'll probably help you. I think?
Old Jan 25, 2007 | 04:00 PM
roast's Avatar
roast
If you're trying to learn to shift properly, letting the clutch out too fast probably isn't the problem.... it's all about timing. You can drop the clutch(not that you would actually want to)... and if you do it at the right moment it will be virtually seamless. It's all about matching RPM, yes, even on upshifts.
The Z has a heavy clutch/flywheel...and there is more spacing in between 1st and 2nd than the other gears..... so the higher you take the RPM, the longer you have to wait for the RPM to drop for a proper revmatched up shift. You can always speed shift, but that's another topic.
Old Jan 25, 2007 | 04:07 PM
Barmats's Avatar
Barmats
Agree with above comments. The timing of the 1-2 shift with respect to gas and clutch is the most critical for smoothness. What affects this is the relatively low gearing in combination with vehicle speed and rpm. Any tendency to lurch is definitely felt. If you shift in exactly the same way at the 2-3, 3-4, 4-5 or 5-6 gears, you won't notice it as much.
In much the same way as you balance throttle and clutch for a smooth start, you'll need to find the right amount of gas and clutch for the 1-2 upshift.
Old Jan 26, 2007 | 04:58 AM
Zya123's Avatar
Zya123
Ill keep messing around with it, but i dont shift quick from 1st-2nd and i want to shift quick lol.Its pissing me off cus if i do shift quick it jerks.
Old Jan 26, 2007 | 05:38 AM
ZmanZZZ's Avatar
ZmanZZZ
take ur time when you come off the clutch
Old Jan 26, 2007 | 05:42 AM
fastGkid's Avatar
fastGkid
take your time. our gears suck anyways so if you get good you'll still had trouble shifting
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
seagrasser
Oct 11, 2015 03:27 PM
apex locator
Oct 6, 2015 05:58 PM
