my tires dont smoke up
Old Mar 8, 2007 | 09:56 AM
keosh's Avatar
keosh
Default my tires dont smoke up
Well since i bought my Z I've noticed when i slam the bakes and press the gas my tires spin and skreech from burning out but no smoke at all whats up with that. I bought my 2004 Z used and came with Falken Ziex tires on them and i had to have 2 of them changed since my tires poped when i got into an accident but they were changed into the same exact tires, is there anything wrong with my Z or what i want smoke i love smoke
Old Mar 8, 2007 | 10:11 AM
Sean's Avatar
Sean
smoke is easy, pour some bleach on the tires and burn out, you'll have a white cloud you could fly a plane through
Old Mar 8, 2007 | 10:12 AM
Richy350Z's Avatar
Richy350Z
you sure you're burning out on a dry surface?? not wet?
keosh's Avatar
keosh
na seriously tho why does everyone have to make jokes all the time
Old Mar 8, 2007 | 10:13 AM
keosh's Avatar
keosh
ya i am sure i did it yesterday nothing happendit was dry and very hot as well yesterday in pasadena
Old Mar 8, 2007 | 10:15 AM
Richy350Z's Avatar
Richy350Z
I have no idea what it could be. I've never heard of that problem? You try burning out for longer then 5 seconds in the same spot??
Old Mar 8, 2007 | 10:18 AM
350z2go's Avatar
350z2go
slam da gas and hold the brake you will get smoke hahah sometime
Old Mar 8, 2007 | 10:51 AM
ceddyluv82's Avatar
ceddyluv82
That what your problem is. You are "slamming" the brakes. To do a burnout you need to apply just enough so that the brakes hold the car a bit so you can get the tires to start rotating at the same time. Then you let off the brakes and go at it. If you are wondering why you see some guys just SIT there and light up their tires.. it's because they have the rear brakes disconnected. They can just lock up the fronts and go at it all afternoon. Bleach burnouts also make the smoke really really white and alot of it lol Your tires have nothing to do with it, unless you have like drag radials or R compounds. They stick to the road better which means harder to break contact. Hope this helps.
Old Mar 8, 2007 | 10:53 AM
rocks's Avatar
rocks
Pull the stop lamp fuse out. When you try and do a burn out with the brakes the ecu cuts the power to the engine so you cant.
push's Avatar
push
Hopefully you aren't sitting there burning up your clutch from pressing down on the brake pedal too hard haha.
Old Mar 8, 2007 | 10:54 AM
ceddyluv82's Avatar
ceddyluv82
Wow really? Even with the manual?
Old Mar 8, 2007 | 10:55 AM
keosh's Avatar
keosh
ya i do it for a while and ill try what u said ceddyluv82 today see if it works out
Old Mar 8, 2007 | 11:00 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
Exclamation
TURN THE TCS OFF
for god sake man, you can roast tires all day long in an AT or 6spd bonestock.
Old Mar 8, 2007 | 11:03 AM
CaliTouring's Avatar
CaliTouring
Arent you guys worried about the bleach getting on the paint?
Old Mar 8, 2007 | 11:35 AM
ceddyluv82's Avatar
ceddyluv82
I have never roasted my tires with bleach...I have only heard of people doing that at burn out events etc... you dont exactly want to inhale(sp?) burning bleach smoke...
Old Mar 8, 2007 | 11:43 AM
DROPPEDIT2WCE
what is the need to do a burnout in a nice new Z? even at the track unless you have slicks or DR's it's really not gonna help much with your 60' or 1/4 time or trap speed... Just abuse on the car really
Old Mar 8, 2007 | 11:52 AM
mdracer76's Avatar
mdracer76
With all the accidents, and burnouts one day you'll be as cool as this guy.
lame.
Old Mar 8, 2007 | 11:53 AM
A line lock will help.
Old Mar 8, 2007 | 12:17 PM
SOCAL350's Avatar
SOCAL350
Pasadena CA?
If you cant figure it out Ill take you down to the rose bowl and show you.
Old Mar 8, 2007 | 01:12 PM
VO...'s Avatar
VO...
Administrator
+1
VO(wouldn't throw his $650 worth of rear tire rubber down the drain)
