LSD, How do I know what has it?
Old Mar 16, 2007 | 09:24 AM
STLTA's Avatar
STLTA
Default LSD, How do I know what has it?
I am looking at 350z's, all years, and I am accustomed to a limited slip rear end. How do i know which ones would have it? I am only looking at 6 speeds... I have heard that the g35's all have it if you get a manual, is this true? is it the same for the 350z?
Lastly, does it actually matter that much on these??
New guy, thanks for the help.
Old Mar 16, 2007 | 09:29 AM
DavesZ#3's Avatar
DavesZ#3
If I remember correctly, only the Base Model Z doesn't get the LSD. All others, AT or MT should have a LSD.
Does it matter? Yes. Get a Z with the LSD. You have too much power to put down through just one wheel. By avoiding the Base, you also get cruise control.
Old Mar 16, 2007 | 10:02 AM
The Brickyard Rat's Avatar
The Brickyard Rat
All Zs except Base have LSD. If the steering wheel does NOT have any buttons for cruise control it is a Base & does not have LSD. If you see buttons on wheel, it has LSD.
Old Mar 16, 2007 | 10:04 AM
zand02max's Avatar
zand02max
Certain G models do not have the LSD!
Old Mar 16, 2007 | 10:11 AM
Category5's Avatar
Category5
1) Base-model is only model that has open-diff. If you're not sure on model, during test-drive, shift into second at high-rev. If no LSD, your back-end will fishtail (alternative: accelerate while making 90-degree turn. Car will feel like it's standing still).
2) You need a LSD, if you want to even be a little aggressive. See 1) above.
3) If possible, get a base, and then get an after-market Quaife LSD ($1400), which is superior to the VLSD that comes with the other models.
Old Mar 16, 2007 | 10:55 AM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Welcome!
Do A Search!
Old Mar 16, 2007 | 10:58 AM
drivenCSZ's Avatar
drivenCSZ
+1 simple easiest answer. Buttons on steering wheel =LSD
Old Mar 16, 2007 | 01:32 PM
alan86's Avatar
alan86
how loud is the Quaife LSD, i heard an aftermarket lsd is not worth the mod because its so annoying and not ideal for daily driving?
Old Mar 16, 2007 | 03:29 PM
Nismo 350z's Avatar
Nismo 350z
If the car has TCS/VDC then you have a LSD on there. If u dont have that feature then you dont have a LSD. The only model that doesnt come with TCS/VDC is the base. Common sense.
Old Mar 16, 2007 | 07:16 PM
ambientflier's Avatar
ambientflier
Is there any way to adapt traction control and/or stability control to the base model? Parts from a wrecked z, or aftermarket?
Old Mar 16, 2007 | 08:26 PM
tranceformer95's Avatar
tranceformer95
I wouldn't bother with the traction control. The aftermarket LSD might be worthwhile.
Old Mar 17, 2007 | 09:25 AM
Category5's Avatar
Category5
The Quaife is as quiet and seemless (you won't notice it during regular driving) as the VLSD. You're refering to the clutch-type LSD. This type has multiple settings that vary the amount of slip. If adjusted for minimal slip, this type can be very noisy. This type is also high maintenance. The VLSD uses liquid, which deteriorates over time. The Quiafe is gear-type. Both of these are low/no maintenance. The VLSD doesn't react to slip until it is already occuring. The Quaife is much better at preventing silp, and doesn't deteriorate over time.
Old Mar 17, 2007 | 04:19 PM
bailey bill's Avatar
bailey bill
Originally Posted by Scarab440
with so many people switching around parts.. if you jack up the rear and spin one of the rer wheels if the other wheels spins the oppoiste direction you have a LSD.
That rule does NOT apply to viscous systems, like the Z.
bill
Old Mar 17, 2007 | 04:20 PM
Scarab440's Avatar
Scarab440
bill
very interesting. sorry for this misinformation.. Editing orignal post so it doesn't propigate...
Old Mar 17, 2007 | 04:39 PM
bailey bill
Your response is commendable. This is an idea that applied to various mechanical-type LSDs on older cars that is not applicable to most of the modern LSD arrangements. But I still see it being posted on different message boards.
So this is good place to dispell that myth.
bill
Old Mar 19, 2007 | 12:25 AM
xplosiveG_06's Avatar
xplosiveG_06
if it does a burnout with both rear wheels
Old Mar 19, 2007 | 06:08 AM
bailey bill
Also not a meaningful test. Well-balanced cars with properly designed suspension systems will spin both rear wheels, even without LSD.
Look, in the case if theZ, this is not difficult. If its a base, it doesn't have LSD. All other trim levels do.
bill
Old Mar 19, 2007 | 06:48 AM
amsweigart@hotm's Avatar
amsweigart@hotm
Wish I had some LSD umm a LSD on my car .
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
