Gas gauge inaccuracy
Old 04-07-2007, 01:31 AM
ray427
ray427's Avatar
Default Gas gauge inaccuracy
Gas gauge reads about 1/4 tank, i fill up with 9 gallons. anyone hae this problem before. ALSO, does anyone use the dte gauge and if so how accurate would you rate it?
2003 touring 6 speed
Old 04-07-2007, 07:52 AM
PDX_Racer
PDX_Racer's Avatar
Normal.
Very few gas gauges measure from completely full to completely empty. It is just an estimate of relative fuel.
You can do a quick guesstimate of miles by just calculating 20 gal (I know the tank is 21 gal, but you really don't want to go that low) times your mileage. At an average of 20 MPG, you can get 400 miles out of a tank. At 25 MPG, you're looking at 500 miles.
Old 04-07-2007, 07:58 AM
PythonLaX
PythonLaX's Avatar
I use the mpg computer, reset it every time I fill up, and its very accurate.
Old 04-07-2007, 08:18 AM
jimster716
jimster716's Avatar
I fill up and the gauge never shows FULL, it's always showing like 7/8ths full. I get the yellow light and the DTE gauge shows 39 miles, I try to fill up and I can only fill up about 12-13 gallons...which probably indicates that the gauges are always about 2 gallons lower than true.
The dealer repaired it the first year I had it ('03) when the gauge just stopped working period. I just attribute it to Nissan quality LOL. My Acuras/Hondas and Toyotas never had this many niggling quality issues.
But alas, having the gauge show less gas than I really have is better than the gas gauge showing that I have more than I really have.
Old 04-07-2007, 09:20 AM
DIGItonium
DIGItonium's Avatar
Did you have a fuel filler cutoff valve issue? Sometimes when you try to fill up it cuts off as if the tank is full, but you already had a few gallons in.
Old 04-07-2007, 09:42 AM
craZ350
craZ350's Avatar
i have this problem too. gauge never goes to FULL when i fill up. my '95 Nissan 200sx never had this problem and it's a cheaper car!
Old 04-07-2007, 09:56 AM
Ztalker
Ztalker's Avatar
the dealer had to replace the sending unit inside the gas tank of my 05 armada cuz the sucker was reading only 3/4 full after fillups.
Old 04-07-2007, 11:15 AM
iknowitsfast
iknowitsfast's Avatar
My 03 Touring 6mt is iffy. Lots of times it never shows full even when i top it off. But then other times the needle goes all the way to full...wierd.
Old 04-07-2007, 01:08 PM
NightRida
NightRida's Avatar
I got an an 07 and so far no problems.
Peace!
Old 04-07-2007, 01:12 PM
blasian
blasian's Avatar
MY gas light normally doesn't come no until about 15-17 gallons and its been that way since I got the car. Just about every car I've had didn't give a light until it was about 2-4 gallons low.
Old 04-07-2007, 01:19 PM
realcom2
realcom2's Avatar
I have the same problem where it appears to be less than 1/4 tank but then only takes about 9 gallons in my 2005 Z. It really doesnt bother me that much cause I try to keep my tank full.
Old 04-07-2007, 02:43 PM
kdogg24
kdogg24's Avatar
I had a similar problem, so I took the Z into a dealership under warranty, and they found the fuel sensor system to be loose in the tank, so they ordered the parts needed and replaced the entire system. Now it works perfectly, (knock on wood)
Old 04-07-2007, 03:03 PM
I1DER
I1DER's Avatar
There are dozens of posts to this issue(s) and several answers. Make yourself knowledgable about your car and do a search.
Old 04-08-2007, 08:56 AM
NismoKiller
NismoKiller's Avatar
Dont really care. I always keep 1/2 a tank. Less wieght!!
Old 04-14-2007, 01:13 PM
NismoKiller
u think u have it bad?? my cup holder doesnt come out!
Old 04-14-2007, 04:05 PM
tmak26b
tmak26b's Avatar
There is a TSB on the fuel tank issue. The Z fuel gauge is very sensitive anyway, it can go from top to bottom within seconds
Old 04-14-2007, 07:16 PM
Κράτος αστυνομίας
Κράτος αστυνομίας's Avatar
My sunroof won't open!
Old 04-15-2007, 03:53 AM
JAB_06-350Z
JAB_06-350Z's Avatar
So far the gas gauge seems to be very accurate on my '06. Hope it stays that way.
Old 04-15-2007, 07:06 AM
Zya123
Zya123's Avatar
I had this problam, I took it back to the dealer because It first would say I have a full tank when I only put 12 gallons in, because of that I am getting horrible MPG, They said they found a sensor that is bad and I have to bring the car back next week for them to install the new part, If you have an extended warrenty its covered, mine is I only have to pay a $50 deductable
Old 04-15-2007, 10:00 AM
Zmazing03
Zmazing03's Avatar
From my experience, Nissans have weird gas gauges. Both my step moms Altima (2006), her old Maxima (1999), and my Z (2003), they all have the same gas gauge "issues". It tends to take forever to go from Full to 1/2 tank, but once you get to 1/2 tank it falls to E at least 40% faster than when I was going down to 1/2. Annoying, but I have noticed this in all three of the cars.
Quick Reply: Gas gauge inaccuracy
