burning out safety
Old Apr 23, 2007 | 09:18 PM
surfnaked425's Avatar
surfnaked425
Default burning out safety
i cant burnout with my z cause it has a safety thing is there a way to take it off ? so i will beable burn out
Old Apr 23, 2007 | 09:20 PM
Sean's Avatar
Sean
turn off your traction control, but don't drive around with it off, make sure you turn it back on when you are done killling your tires.
Old Apr 23, 2007 | 09:23 PM
cleanandquick06's Avatar
cleanandquick06
no no no, he is talking about everytime he trys to powerbrake it cuts the throttle. you take out the fuse for your anti skid there buddy. but you have to take it out. burn out, then put it back in to drive. did it once just to get some good picks and say ive done it, park your car at a slight angle, (without taking the fuze out) spin first gear, then after a few seconds shift to second, then after a few more shift to 3rd and you will get a loooong smokey burnout, but you do alot of wear to your car
Old Apr 23, 2007 | 09:27 PM
Aldweik's Avatar
Aldweik
Pull the brake fuse from the driver side fuse box. You can wire up a fused switch to that fuse slot if you will be using this often at the drag strip. It goes without saying of course, "not road legal" because this disables your VDC - ABS and brake light while the fuse is pulled.
Old Apr 23, 2007 | 09:28 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Any bets on how long it is until we are reading about a crashed Z in Oahu?
Old Apr 23, 2007 | 09:30 PM
garyovich's Avatar
garyovich
my $'s on less than a month. maybe flipped doing 20mph on an on-ramp?
Old Apr 23, 2007 | 10:07 PM
surfnaked425
where is the fuse for your anti skid located ?
Old Apr 23, 2007 | 10:08 PM
keosh's Avatar
keosh
Traction Controle Off
Old Apr 23, 2007 | 10:26 PM
pimpin714style's Avatar
pimpin714style
Why Not Just Get A Line Lock For The Front Brakes???
Old Apr 23, 2007 | 10:30 PM
surfnaked425
whats a line lock ?
Old Apr 23, 2007 | 10:35 PM
surfnaked425
is it hard to install a line lock ?
Old Apr 23, 2007 | 11:07 PM
Korki Buchek's Avatar
Korki Buchek
You don't want a line-lock.
Korki Buchek
Owners Manual: Index.
Old Apr 23, 2007 | 11:16 PM
Aldweik's Avatar
Aldweik
If I remember correctly its a red 10amp mini-fuse behind the driver-side kick panel. The Z has a safety feature that kills the power if the brake light is on and the gas padal are being pushed simultaneously with the clutch out. It is the fuse for the brake light that enables this feature to work. Once again - it is illegal to do this on the road, it impairs the safety of the vehicle.
Old Apr 23, 2007 | 11:22 PM
surfnaked425
thank you for your help
Old Apr 24, 2007 | 12:42 AM
Korki Buchek
Just remember, a new set of stock tires is close to (over?) $200 a pop.
Trust me, you'll never win a burnout contest. There will be some guy there in an '81 Lincoln Towncar on 13's with tires that cost him $.49 cents apiece and he will burn them to the metal because he's going to drive home going 3 miles per hour in 3 wheel motion anyway. Haven't you ever seen lowrider magazine?
Old Apr 24, 2007 | 12:49 PM
mbb350z's Avatar
mbb350z
cant u just hit the tcs button and have fun at least in my 07 u turn it off u can burn them or kick it out anywhere
Old Apr 24, 2007 | 01:20 PM
JAB_06-350Z's Avatar
JAB_06-350Z
Ok kid, with all that info.......
BURN BABY BURN!!
Old Apr 24, 2007 | 02:40 PM
Steve-O Z33's Avatar
Steve-O Z33
I've read countless times, even from pro drag racers that it's pointless to do a burnout if you're using street tires. If you're talking about just doing it for fun, then ok... go kill some tires.
Old Apr 24, 2007 | 04:15 PM
robbinthehood's Avatar
robbinthehood
damn. so you cant even left foot brake if the car starts to understeer in a 350z or is it with a lot of pedal pressure on the brake?
