constant using of bio ethanol
Old May 10, 2007 | 05:49 AM
dima_finn's Avatar
dima_finn
Default constant using of bio ethanol
Greetings from Ukraine.
Going to buy this used Z350
Does anyone know how will constant using of bio ethanol effect on this Honda’s engine? I mean, wouldn’t it be bad for a car? The Authorized Honda Centres in Ukraine has no answer. The Ukrainian Honda forums also haven’t got a clue. So, I rely on your experience and knowledge.
Many thanks for any help.
Old May 10, 2007 | 05:59 AM
Gooey's Avatar
Gooey
First its not a Honda. Its a nissan. Try another dealership =)
Old May 10, 2007 | 06:27 AM
hardrock905's Avatar
hardrock905
It's a Nissan, not a Honda. It cannot run on bio ethanol fuel. It requires premium unleaded with an octane rating of 91 or higher if possible.
And it's a 350Z, not a Z350. This may help on your search for information.
Old May 10, 2007 | 06:52 AM
Welcome. Do you have a photo of a Honda Z350? I have never seen one.
Old May 10, 2007 | 07:03 AM
Tac-M's Avatar
Tac-M
It may be possible, i assume it would take a ECU menagement like e-manage, or Utech.
Anyway, nikto neznaet ! esli nashi patzani sdelaut, skazi nam !
Old May 10, 2007 | 07:05 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
You can use ethanol but will need to tune the car for such and use different injectors. Eventually your seals may crack.
Shift_Z33's Avatar
Shift_Z33
Blasphemer!
Old May 10, 2007 | 07:25 AM
dbasal's Avatar
dbasal
VTEC just kicked in, YO!
Now if the brain would do the same......
Old May 10, 2007 | 08:12 AM
hardrock905
I imagine he was wondering if the Z could use ethanol in stock form.
If not, sounds like a huge PITA and a risk to do so.
Old May 10, 2007 | 08:24 AM
Tac-M's Avatar
Tac-M
We are on 15% ethanol already! And GM has flex-fuel cars, so it can’t be THAT hard to adjust.
Old May 10, 2007 | 08:45 AM
hardrock905
Ok. So explain how this could easily be done for the Z.
One problem with ethanol is that the octane rating is too low for the Z.
Another issue is with the extra equipment needed to run E85, evap canisters I believe are just one item.
Old May 10, 2007 | 08:47 AM
Jim@Showstoppers
Tune,you must tune your car to run on lower or high octane.
Old May 10, 2007 | 09:21 AM
hardrock905
So you would basically have to de-tune the Z, decreasing it's performance?
Old May 10, 2007 | 09:41 AM
Jim@Showstoppers
Not "detune" but re-tune to get the correct A/f, timing, spark advance, etc.
Just like you would have to do if running on race gas.
Jim
Old May 10, 2007 | 10:33 AM
davids's Avatar
davids
F U StuLax18
You might want to check out an RSX. Those run on anything and everything including peanut butter and jelly sandwiches.
Old May 10, 2007 | 10:49 AM
redlude97's Avatar
redlude97
Might wanna check on the octane rating on ethanol again buddy
Old May 10, 2007 | 10:59 AM
Tac-M's Avatar
Tac-M
http://en.wikipedia.org/wiki/E85
E-85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such flexible-fuel engines are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. The primary differences from non-FFVs is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system, the use of fuel pumps capable of operating with electrically conductive (ethanol) instead of non-conducting dielectric (gasoline) fuel, specially-coated wear-resistant engine parts, fuel injection control systems having a wider range of pulse widths (for injecting approximately 60% more fuel), the selection of stainless steel fuel lines (sometimes lined with plastic), the selection of stainless steel fuel tanks in place of terne fuel tanks, and, in some cases, the use of acid-neutralizing motor oil. For vehicles with fuel-tank mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used.[citations needed]
Old May 10, 2007 | 11:04 AM
Tac-M's Avatar
Tac-M
one more part from wiki...
Power output and usage in racing
E85 has been repeatedly shown to produce more power than a comparable gasoline fuel, especially in engines that need high octane fuels to avoid early detonation.[3] Ford Motor Company found that power typically increased approximately 5% with the switch to E85 [4]. Researchers working on the equivalent of E85 fuel for general aviation aircraft AGE-85 have seen the same results with an aircraft engine jumping from 600 hp on conventional 100LL AV gas to 650 hp on the AGE-85. Recorded power increases range from 5% to 9% depending on the engine. [5][6]
Due to pressure to remove leaded fuel even from racing environments, several racing organizations are looking at ethanol or E85 fuels as suitable alternative fuels for high performance race engines.
In 2007, the Swedish Touring Car Championship, STCC, will have cars running on E85.
In Swedish rallying, as of 2006, approx. 30% of competitors were running their rally cars on E85. There is also a rally cup (Ford Flexifuel Cup) using Ford Fiestas in Gr. N, which started in 2006.
In 2006, the National Street Car Association is adopting E85 as an approved fuel for both their American Muscle Car and Street Machine (racing class) eliminator racing classes.
The National Hot Rod Association (NHRA) currently allows ethanol as an approved fuel in several of its racing classes. NHRA approved ethanol is allowed in their bracket classes, Hotrod, Modified, ProFWD, and ProRWD classes to name some of the more popular. At this time NHRA has not announced any plans to include E85 as an approved fuel in the classes that are currently limited to "pump fuels".
The Indy Racing League moved to ethanol based fuels in 2006, with a 10% ethanol 90% methanol fuel blend, before switching to a 98% ethanol 2% gasoline fuel in the 2007 IndyCar Series racing season.
General Motors Performance Division's GM Student Cobalt driven by Mark Dickens went 172.680 mph at Bonneville Speed Weeks August 2006, setting a new record for G/FCC class on E85 fuel. This run broke a 19-year-old record of 152.626 mph set by Doc Jeffries in 1987. [7]
There is much discussion of NASCAR also making the switch to an ethanol based fuel in the future. During selected 2006 Craftsman Truck Series races, the Chevrolet Silverado pace truck, such as the one in the GM Flex-Fuel 250, will be fueled by E85, and a marketing campaign with Morgan-Dollar Motorsports resulted in one of their trucks' numbers changed to #85 to promote E85 fuel such as the one used in the pace truck.
In 2006, Shell announced V8 Supercar will use Shell Optimax Extreme, a premium unleaded fuel blended with five percent ethanol.
Interest in E85 is high enough that there are now competitions for engine builders to develop winning combinations for both power and fuel economy on this fuel. One such competition is sponsored by the AERA Engine Builders Association
Old May 10, 2007 | 11:08 AM
hardrock905
Wow. I was mistaken by a long shot. My bad.
Old May 10, 2007 | 11:12 AM
jimmyloose's Avatar
jimmyloose
The company that comes to the market with an E85 conversion kit for older vehicles is going to make a killing
