2007 350Z Review ...
Old May 26, 2007 | 04:28 AM
three_fifty_z's Avatar
three_fifty_z
Thumbs up 2007 350Z Review ...
We’re at Tsukuba Circuit, Japan’s most popular race track, for an early drive in the new Z-car. As I exit the final hairpin in second gear and bury my right foot, the tacho needle heads past 6000rpm… What happens next is what differentiates the new 350Z from the current model. Where the current V6 revels in the low to mid-ranges but fizzles out above 6000, the new engine fairly rockets through 5000rpm and just keeps pouring on the power. By the end of the back straight, the new Z is tickling 125mph and just getting into its stride…
The current 350Z has long been an evo favourite. It looks the part, sounds great, steers well and has enough power to jump from zero to 60mph in under 6 seconds. It has certainly done its bit to keep the 37-year-old Z legend alive, with more than 200,000 sales around the globe. And its ‘VQ’ 3.5-litre V6 has kept racking up the engine awards, winning America’s Wards gong every year since the turn of the century. But having just planted a brand new 3.5-litre V6, the VQ35HR, under the bonnets of the new Skyline and Infiniti G35, Nissan thought it was high time for another major transplant, this time into its hottest coupe.
With its new power unit, the mildly facelifted 350Z pumps out a healthy 313bhp at 6800rpm, up from 296bhp at 6400, while peak torque rises a smidge to 264lb ft at 4800rpm, though that’s only part of the story. You’ll have to look closely to spot the cosmetic changes. In fact the only sheet-metal modification was made directly above the powerplant. The new V6 uses 80 per cent new components, including a revised block and induction system that together add some 15mm to the height of the engine. That’s the reason for the new bonnet bulge, which is also a visual nod to the original 240Z. The only other outward changes are slightly different lights and some new colours, including the ‘Premium Passionate Orange’ of our test car.
But it’s only fitting that attention should be drawn to the new engine, because it plugs what was the biggest gap in the Z’s dynamic performance and lifts the driving experience a whole notch.
It took just two corners of Tsukuba to realise just how much more freely the new HR unit spins to the 7500 red line. The outgoing VQ engine had loads of punch down low, but lacked staying power through the top end. The HR fixes that nicely. Boasting a drier but beefier exhaust note that takes on an addictive roar above 5000rpm, the new V6’s torque curve has filled out in all the right places: while its newly found high-end vigour will encourage you to keep the engine on the boil above 5000rpm, there’s more torque low-down too.
Another hairpin at Tsukuba, and I allow the rev-counter to drop to just 2000rpm. I floor the throttle again and this time my gob is smacked by the torrent of torque that surges forth and doesn’t seem to let up, right up to the 7500rpm red line. On a track, at least, the new Z is the business. With a chassis that’s still happy to indulge you, and powerful brakes too, the revised model is even more of a blast than its predecessor. Most of all, it makes you want to hold on to gears just to savour the rush of power and sound.
And out in the real world too, the new Z’s an improvement, the wider torque curve making even town driving a pleasure. We also took the new car for a spin around the mountain roads south of Tokyo. At normal speeds, the Z’s steering is as precise and turn-in as sharp as it’s always been. There are no major modifications to the car’s suspension, just slightly revised damping. However, the newly fitted Bridgestone Potenza RE050 tyres (225/45 18s on the front, 245/45 18s at the rear) seem to provide slightly more grip at regular road speeds, while also lowering noise levels and improving the ride.
Back on track, push the Z as we did through Tsukuba’s long right-hand sweeper and it will understeer at first, but feather the throttle and understeer soon turns to neutrality before you can use the Z’s extra torque to steer on the throttle – and it all happens even more progressively than before. The extra top-end means that the rear will break traction even more easily, but also that the slide is easier to hold.
Thanks to that all-new V6, Nissan engineers have taken one of Japan’s best sports cars and targeted its one weak spot – that shallow top end – to produce a truly great drivers’ car. You’ll want to keep it hovering between 5000 and 7000, just like I did – but you won’t panic when the needle falls below three-grand either. It still sounds loud and proud, too – and why not? The 350Z is something we should all celebrate.
if you want a link you can find it here http://www.evo.co.uk/carreviews/evoc...ssan_350z.html
Old May 26, 2007 | 07:50 AM
EdH350Z's Avatar
EdH350Z
Excellent post, and I know it is a mag review. I prefer the European mags reviews better than the advertisement-heavy US mag wholes. This is the very reason I bought a 2007 350Z. I am long in the tooth, since I am a early enthusiast of the Z saga from my early 240Z and 260Z days.
Old May 26, 2007 | 07:56 AM
three_fifty_z
ha ha yeah thats why i provided the link to show its from EVO magazine. It scored 5 out of 5 stars and this magazine is a dedicated performance type. Just goes to show how good the 07 350z is.
Old May 26, 2007 | 01:15 PM
dannemare's Avatar
dannemare
Wow, loved that review. I am about to make an appointment for a test drive when the '07 arrives in Sweden (should be in June). Dunno why it arrives so late in Sweden compared to the states (but it's actually the same for all of Europe, right?).
Due to big payments on our current cars I won't be buying until spring 2008, however, and maybe I'll even wait for a '08 (with tranny/clutch fixes, hopefully) assuming it won't be coming later than June 2008 and assuming it's not a complete redesign as I really, really like the current look and performance package (the VQ35HR will be more than enough for me, coming from a BMW 530d (E39), and a Rover Sedan 620Si before that ).
B/R,
Frederik Dannemare
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
codek
Sep 28, 2015 03:03 AM
