Adjustment warranty
Old May 30, 2007 | 05:53 AM
Category5's Avatar
Category5
Default Adjustment warranty
I have a 2005 (purchased new) with 8000 miles. I took the car to dealer with the rear-axle clicking. He indicated that this was an "adjustment", which falls under the adjustment-waranty of 12months/12500miles. My Waranty-manual clearly indicates this special adjustment-waranty. After 15minutes of debate, he won ($120 for both axles). Question: This sounds reasonable because no "part" failed, but does the existence of a TSB override the 12month, i.e., does the TSB have any trump-power like a recall, or is the TSB just 'notes' for the service department?
Old May 30, 2007 | 06:11 AM
SirSpeedyZ's Avatar
SirSpeedyZ
smells like BS to me, your car is under warranty, ie they should fix it
Old May 30, 2007 | 07:26 AM
A service bulletin is an addendum to the maintenance manual. It tells technicians how to fix stuff. Because there is a service bulletin does not automatically mean that it is a warranty fix.
Clicking rear axle is a deficiency in materials and workmanship. Do the rear axles of all vehicles click? No. So why does the 350Z rear axle click? Because it is a deficiency in materials and workmanship. All deficiencies in materials and workmanship are covered by warranty.
Old May 30, 2007 | 07:27 AM
blasian's Avatar
blasian
Got my clicking fixed with about 50k miles under the powertrain warranty
Old May 30, 2007 | 08:10 AM
]Here is a list of parts needed to fix the axle.
Old May 30, 2007 | 08:21 AM
Tim@WestCovinaNissan's Avatar
The repair is covered under the power train warranty 5yrs 60,000 miles no questions asked. I would question that bill!!!
Old May 30, 2007 | 11:37 AM
Category5's Avatar
Category5
With whom?
Old May 30, 2007 | 04:27 PM
wilson7136's Avatar
wilson7136
I would pull the BS card! My 2005 was covered way after the supposed "adjustment" warranty. Although I have never seen this documented in the owners manual.
Simple question, "what was adjusted"? And since when do new parts and adjustments go together?
Pitch a fit..............
Old May 30, 2007 | 05:06 PM
bailey bill's Avatar
bailey bill
Replacing axle bolts is NOT an adjustment
You got hosed.
bill
Old May 30, 2007 | 06:42 PM
Fulgore243's Avatar
Fulgore243
Ask to talk to the service manager, if he gives you BS ask to talk to the legal department, I bet they fix it free. xD
Old May 31, 2007 | 05:23 AM
Category5's Avatar
Category5
You got hosed.
bill
I'm sure I did. Note: The TSB covering this issue warns that if the axle locking-nut is re-tightened too tightly, the clicking will re-occur. So, regardless of how many times you replace the axle bolts, "adjustment" is clearly part of the problem.
Old May 31, 2007 | 08:23 AM
Z-T's Avatar
Z-T
Was this issue resolved in newer Z's?
Wondering if this is something I need to deal with on my '07.
TIA.
T.
Old May 31, 2007 | 08:33 AM
Bevo's Avatar
Bevo
TIA.
T.
There you go,
https://my350z.com/forum/forumdispla...aysprune=&f=53
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
