How do I get my interior lights to work?
i tried clicking them, nada...doesn't even turn one when I open the doors...this could be a ***** at night-time...btw, i do have it on "door"...i read the manual but coouldn't find anything that's gonna help me....
is there some kind of button or something in the interior that controlld the lights?
there is a sliding switch in the ceiling console that says whether they are all on, all off, or on when doors are open. but the 2 lights up there should go on when you push them, as well as the trunk one should go on when you open the trunk.
Sounds like your BCM (body control module) is bad.
http://www.nissan-techinfo.com/nissa...1.asp?mscssid=
Mine was the same way.
Talking about interior lights, any one know how to turn off the light in the rear hatch area that turns on when the hatch is open?? I'll be at a local event where the hatch will be open about 10-12 hours.. I really don't need a dead battery from that little light..
Any one know how?? Short of removing the bulb??
Thanks in advance..
Steve (k2we) Dobbs Ferry, NY 7323 miles since Sept 17th.....
Thanks in advance..
Thanks in advance..
Thanks in advance..
Should not take long. it is behind the panel that has the fuse box access. Do take all your keys and remotes with you as they will need to be reprogrammed.
BTW - All lights will only stay on for a maximum of 20 minutes before the BCM turns them off to save battery after key is removed from ignition.
Originally posted by durobred
so are you sayin few min. or few hours?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
