What makes it a .5?
Old Aug 29, 2007 | 03:23 PM
  #41
arejohn's Avatar
arejohn
Default Tire feathering anyone
Tire feathering anyone. My favorite subject. Here' s what I think: it has NOT been fixed although many no longer have the problem by changing to tires with less stiff side walls and getting the alignment set to the updated toe +/-. I find this +/- spec to be BS as this exceeds any alignment machine's spec or accuracy. The stiffer inside tread blocks on the updated Bridgestones only reduce the rate of feathering. Too little toe and you get feathering, too much toe and you get cupping.
Also, if Nissan fixed the tire wear problem what did they change. I can't find any
info on updated suspension parts.
As for the 4.5 and softer Euro suspension- how do you increase rear spring rate 100lbs and soften the ride. You have to soften the shocks. I haven't seen any info on shock updates. The spring rate charts I have seen do not differentiate C vs. R. Would they have the same rate?
Would someone from Nissan parts department to do some part number look up and get it into the FAQ?
Old Aug 29, 2007 | 03:48 PM
  #42
DavesZ#3's Avatar
DavesZ#3
The "fix" was to properly align the toe on the front end. Nothing more than that.
Old Aug 29, 2007 | 11:42 PM
  #43
medic165's Avatar
medic165
Originally Posted by 350Zenophile
Wait. Your 19's are likely wider and have more aggressive offsets which will affect your camber.
thanks "350Zenophile". I'll wait for the 19"s to do the alignment.
Old Sep 7, 2007 | 12:03 PM
  #44
Dui-Dan's Avatar
Dui-Dan
d94m102357 that means its an 04.5 right? did the 2004.5 have the 008 or 009 tranny in it?
Old Sep 7, 2007 | 12:37 PM
  #45
sluggoZ's Avatar
sluggoZ
Originally Posted by medic165
i'm sure is out of spec, but i'm getting new 19's wheels/tires. Should I get an alignment now with the OEM 18's? or should I wait to have it done with the new 19's on the car?
You should get the alignment now. Your car does not know whether it has 17's, 18's or 19's.
Old Jan 22, 2008 | 07:26 PM
  #46
twitch579's Avatar
twitch579
04.5 has the 008 tranny, thats what they pulled out of mine when it was changed to a 009.
Old Jan 22, 2008 | 08:35 PM
  #47
2boosted4u's Avatar
2boosted4u
do all the 2003-2004.5 have a recall on the trannys?
Old Jan 23, 2008 | 03:13 AM
  #48
DavesZ#3's Avatar
DavesZ#3
There are no recalls on transmissions. If you have a defective one, they replace it with the new one.
Old Feb 6, 2008 | 08:29 AM
  #49
Datapimp's Avatar
Datapimp
Originally Posted by DavesZ#3
Correct, all the "M" cars are 04.5s.
Any difference between the T and the M, with the 04.5?
Old Feb 6, 2008 | 08:57 AM
  #50
DavesZ#3's Avatar
DavesZ#3
Manufacturing location:
T = Oppama
M = Tochigi
Old Feb 6, 2008 | 09:05 AM
  #51
Datapimp's Avatar
Datapimp
T = Oppama
M = Tochigi
So all Z production wasn't moved from Oppama to the Tochigi plant for 04.5? That’s what I thought was one of the main differences. I was wrong.
Thanks Dave
Old Feb 6, 2008 | 11:12 AM
  #52
rockinbboy's Avatar
rockinbboy
Originally Posted by dspiel
i have an 2006.5 anyone know difference between an 06?
flux capacitor
Old Feb 6, 2008 | 11:32 AM
  #53
MUZZY's Avatar
MUZZY
only difference in a 04.5 is tat it was made in the takigi plant when they swtched half way in the year and the takigi plant build the Z's with the 05 specs, so the tire feathering and little stuff like that are fixed
Old Feb 11, 2008 | 10:47 PM
  #54
NismoFan47's Avatar
NismoFan47
Tire feathering can be fixed by just getting a tired alignment right? If not, is it really that big a deal? I'm looking at an 04 right now, it has knee pads, but I know it's not a 04.5....is it that big of a deal to just get an 04? This thread is scaring me.
04 350z Touring with 18K mi on it, btw.
Old Feb 12, 2008 | 03:13 AM
  #55
DavesZ#3's Avatar
DavesZ#3
Yes, the "fix" for feathering was to get and keep it in proper alignment.
Old Feb 28, 2008 | 06:40 PM
  #56
grey00lustre's Avatar
grey00lustre
Last 10 digit of my Vin are E24M155443. Do I have a 04 or 04.5 model?
Old Feb 29, 2008 | 03:21 AM
  #57
DavesZ#3's Avatar
DavesZ#3
"Mxxxxxx" cars are all 2004.5
Old Feb 29, 2008 | 03:30 AM
  #58
Doba's Avatar
Doba
hers an example:
E24T155443 would be 04 cause of the T15
E24T165443 would be 04.5 - T16
E24M155443 would also be 04.5 - cause of the M (new plant) like mentioned above
Old Jun 18, 2008 | 02:54 AM
  #59
Monty350's Avatar
Monty350
My VIN is European?
JN1 GAA Z33 U01 005 03
So, which model do I have?
Old Jun 18, 2008 | 03:14 AM
  #60
DavesZ#3's Avatar
DavesZ#3
That doesn't appear to be a valid VIN number.
