fuel filling problem
Originally Posted by roast
All these half baked explanations and cockamamie snake oil remedies are bs. Take it to the dealer and have them fix it. The issue is with the shutter valve. There is a TSB for the issue.
your refueler hose has cracks in it, there's no remedy that will cause your gas tank not to build up with pressure from fueling your Z. If you get a full tank it's because your luck. If your there during the install, when they pull the $10 plastic tubing off your car you'll see what i'm talking about.
My 07 did the same thing also. I read somewhere here to avoid filling it up unless it's past the quarter mark, so near empty without actually having the warning light on. She fills up full every single time since.
My 07 has the same problem, depending on the pump. The newest gas station in my area has faster flowing gas which I think causes it to cut off before being full. Slower pumps fill up fine, and if it's cutting off early I just wait about a minute or just pump slower and I can fill it all the way up.
[QUOTE=roast]This problem has been documented to death. Use the search feature. [QUOTE]
i wasnt documenting the problem, i was saying i got it fixed after reading all the posts on here cuz i used the search and it still doesnt work. maybe you should learn to read.
