Engine noise
Old Sep 15, 2007 | 07:59 PM
jonahlw's Avatar
jonahlw
Default Engine noise
I noticed sometimes (or usually) when i accelerate hard, I hear this metallic/rattling noise at around 4-6k. Is this normal? I first started noticing it after installing mrev and spacer. I removed both, but it still makes that noise. What could cause this?
I posted this on G35 forum also (i have a g35), but no one has responded.
Old Sep 15, 2007 | 08:28 PM
Ruthless18x's Avatar
Ruthless18x
How serious of a noise are we talking? I would be willing to bet what you're hearing is the suction from the intake. I wouldnt have removed your spacer and mrev though.
Old Sep 15, 2007 | 08:34 PM
jonahlw's Avatar
jonahlw
just a fairly audible rattle that can be heard coming from the engine at WOT..I know what the intake sounds like, but this sounds more like a resonating as the engine hits a certain rpm
Old Sep 15, 2007 | 08:51 PM
MagicPie's Avatar
MagicPie
theres no normal metallic tapping sound.
I cant think of anything that would cause the problem related to the recent spacer install.
At best the only thing I can think of is the bolts to the plenum could possible be rattling under load, although you would experience other problem for a loose plenum, its still something worth checking
Old Sep 18, 2007 | 12:34 PM
VO...'s Avatar
VO...
Administrator
Check your bolt torque. Sounds like you have a vacuum leak causing this. Mine did it too. How's you idle?
Old Sep 19, 2007 | 01:48 PM
StillenGle's Avatar
StillenGle
did you drop your bolt in the intake housing or anything.
Old Sep 19, 2007 | 08:07 PM
jonahlw's Avatar
jonahlw
well i torqued it by "feel" cause I didn't have a torque wrench, but I just bought one, so now i'm going to retorque and see if that fixes it
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
