Left foot Braking
Old Nov 3, 2007 | 09:16 PM
hidehide's Avatar
hidehide
i want to ask what about the clutch if you use your left foot brake? And do you do heel toe when you coming towards a turn??
Old Nov 3, 2007 | 11:16 PM
Chaser720's Avatar
Chaser720
Lemoned Z
Originally Posted by Z_Driver
You can also use left foot braking if you don't have a line lock to give you a longer burnout at the track to warm up those tires. But, you have to be quick on your feet with a six speed. ;-)
If im not mistaken, the Z has a relay that shuts down the the throttle to 30% when the brakes depressed. Ive tried it and my car just looses RPMs until i stall or let off the gas (and thats in dirt).
Old Nov 4, 2007 | 04:10 AM
john36's Avatar
john36
Sorry if this off topic but how can you bypass the throttle loss when brake is depressed? I want to do standstills Is the only solution a line lock?
Old Nov 4, 2007 | 04:14 AM
marhot's Avatar
marhot
Common for racing & track, but no practical purpose for everyday street driving.
Old Nov 4, 2007 | 09:08 AM
PDX_Racer's Avatar
PDX_Racer
Yes, it's possible to bypass the throttle cut.
I actually use the throttle cut in conjunction with LFB -- it just means that I wait a fraction of a second longer before engaging the brakes.
Old Nov 4, 2007 | 09:20 AM
john36's Avatar
john36
ive tried that and all it does is start the burnout and then bogs like crazy so i have to let go of the brakes and it starts moving
Old Nov 4, 2007 | 09:29 AM
MulhollandDrive's Avatar
MulhollandDrive
I will occasionally use the left foot to brake while applying throttle with the right foot when I need control at low speeds on a truck with an automatic transmission. In this method, the throttle application is constant and the approach to the "target" is controlled with the brake. Left foot braking is also usefull for a full out high stall launch on an auto from a dead start on a car without all those electric cutoff gizmos.
