redline mph shift points for 07 350z?
Old Jan 2, 2008 | 12:25 PM
  #41
Peak350's Avatar
Peak350
Originally Posted by simonfencer
Alberto,
Like I said, no harm, no foul. Tire diameter and gear ratios really don't matter in what I outlined as all you are really doing is comparing engine speed to road speed.
Here is a link to a site that has the formula I mentioned in my post above. It only looks complicated, honest.
http://www.type2.com/library/misc/calcspd.htm
The idea is, say you have a 7500 RPM redline, at 2,500 RPM's you are going xx MPH at redline it will be triple that speed (same gear).
I used to set cruise control in my BMW off of gearing because the speedo was 9 mph off when it said 90 (aka I was going 81). The Z is about 4-5 MPH off at highway speeds, at least, thats what my GPS tells me.
Old Jan 2, 2008 | 04:53 PM
  #42
MagneticZ33's Avatar
MagneticZ33
Originally Posted by Z-Dub
people have done 160mph in a stock '07, or at least that's what the digital speedometer said.
I have an 06 and the other day i hit 160 in 6th at 5500RPM i put it in neutral and reved it and it would not rev past 5600 RPM
Old Jan 2, 2008 | 05:51 PM
  #43
Salvatorey's Avatar
Salvatorey
Originally Posted by Alberto
Whats the point of a flyby if your going 60mph on the brakes when you flyby the camera?
BTW-you speeled TANABE wrong in your sig, spell it right and pick up some ponies...
I was moving at 125mph. ..and you spelled "spelled" wrong.
Old Jan 6, 2008 | 06:07 PM
  #44
JasonCA's Avatar
JasonCA
I thought re-gearing is bad for the engine?
Old Jan 7, 2008 | 10:13 AM
  #45
Peak350's Avatar
Peak350
You technically re-gear everytime you shift, how would re-gearing be bad for the engine. As long as you aren't cruising at high RPM's and starving the engine of oil (more a function of having a big enough oil pan to support the revs) then it shouldn't hurt anything.
Ace2347
Sep 22, 2015 03:12 AM
