Burning smell
Old Jan 2, 2008 | 03:17 PM
Z-Dub's Avatar
Z-Dub
Originally Posted by DraGonAlchemist
what kinda oil do u use? reason i ask is cause when i 1st got the car i was using mobil 1. .and everytime i drove the car hard i smelled a burning engine smell like oil. .so i switched from mobil to elf synthetic. .and no burning smell. .
i just got my oil changed last week. switched to synthetic for the first time to too. i let the dealer do it. i'll see how it goes.
Old Jan 2, 2008 | 03:23 PM
Zmazing03's Avatar
Zmazing03
Wouldn't worry about it. If you redline my Z and the wind is blowing the right direction, you get a slight burning smell as well. '03, 64k miles.
Old Jan 2, 2008 | 05:36 PM
nismo53E's Avatar
nismo53E
FYI...5 minutes isnt really enough time to warm the engine up properly...at least i've noticed in my 07. i watch the oil pressure until it is around 30 psi at idle. i think that is a good indication. takes ~15 minutes. keep in mind that it isn't just the engine either that needs to warm up. tranny and diff need time too...i wont take my car over 3k rpm's until i've been driving at least 15 min...just my 2 cents, though.
Old Jan 2, 2008 | 05:46 PM
Salvatorey's Avatar
Salvatorey
I get that same smell when i run it hard aswell. To be specific, the smell was there when i first drove it...went away...drove it harder...smell came back...went away...drove it even harder..smell came back...went away. since then i've redlined and ran it hard and the smell came back but i think it is the exhaust sealers..the gasket things that melt to fasten the exhaust. I feel it's a heat issue. Once you run it at its max potential, smell should be gone permanently.
Old Jan 2, 2008 | 05:51 PM
Z-Dub's Avatar
Z-Dub
i know man. the car hadn't been off long before i restarted it. temp gauge in the middle and oil pressure low. it was well prepared.
Old Jan 3, 2008 | 07:20 AM
Goku350z2007's Avatar
Goku350z2007
Maybe your Z is farting on you?
Old Jan 24, 2008 | 11:42 PM
vibitzzz's Avatar
vibitzzz
Wow, this is forum is amazing .... i just faced the problem today and here I get the replies .. thanks you all for your contributions ....
Well I am a newBie ... just bought my first Z, 07 2.4K on it ... got oil changes today only juss to be on safer side ....
I asked the manager about what’s the best time to start driving after a cold start ... his answer was quite opposite to what i have read till now... he said you don’t have to wait for a prolonged time after a cold start, in not that super cold temp .... he said 1 min or so is ok ... he also added that if you keep car running idle for a long time it might be bad for the engine... what you all say ....
Old Jan 25, 2008 | 02:13 AM
2007 Z's Avatar
2007 Z
If it was your clutch you would smell it in the car instantly, and very strongly. I've burnt my clutch in several vehicles over the years and they all smelled the same. My worst burn was dropping to 2nd gear at 85 mph instead of 4th. Rear tires lost traction instantly and clutch burnt hard. It stank for 5-10 minutes in the car with the windows down on the highway and I instantly pushed the clutch back in when I realized what happened. So it was only engaged for a fraction of a second.
But the smell is unmistakeable. When you burn the clutch you'll know it for sure.
Old Jan 25, 2008 | 02:17 AM
2007 Z's Avatar
2007 Z
I say give your oil enough time to circulate. I watch the rpms. They start at around 2k or so when I first start it, then they slowly decrease as the engine runs. When my rpms drop to about 1k then I know my car is ready to drive. Usually takes 20-30 seconds or so. I still wait a few more minutes before getting on it hard though.
Old Jan 25, 2008 | 05:17 AM
Forever Z's Avatar
Forever Z
Originally Posted by myZter
burning smell is normal.. i still get it when i gun it on my 06
Me too. I really wouldn't worry.
Old Jan 25, 2008 | 08:53 PM
Boba's Avatar
Boba
lol me too man , got almost 2k on my 07 and when i first ran it hard when passed break-in, i had the burning smell and was so scared that i might be burning the clutch... ran it hard again today for like the 20th time and still got the smell and was a lil worried. And now im surfing the forum and this thread appears just when I need it to. Heh thanks God lol
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
allmycarsdie
May 13, 2016 04:38 PM
smithmt3
Sep 11, 2015 08:25 PM
