Question about wear and tear
Old Feb 1, 2008 | 05:12 PM
THe Emperor's Avatar
THe Emperor
Default Question about wear and tear
OK it snowed bad here again and I got stuck in the alley like usual. In my attempts to get out my tires would spin and my rpms would reach 5-6k alot of times. I had to get press the gas that hard to get out. I just want to know if I'm killing my engine or trans or drivetrain?
Old Feb 1, 2008 | 05:14 PM
Sean's Avatar
Sean
you are making a lot of heat with no real airflow (due to the fact you aren't moving) but at least it's cold out.....just don't make it a habit, try to give it a rest between things like that.
Old Feb 1, 2008 | 05:17 PM
THe Emperor
The only time I go through the alley is leaving home for work and getting home. So once I get into the garage it's in for the night.
Old Feb 1, 2008 | 05:23 PM
Sean's Avatar
Sean
just keep an eye on your temp, if you blow a hose or worse, you will be unhappy.
Old Feb 1, 2008 | 05:49 PM
kramykram's Avatar
kramykram
i would also make sure you are keeping the oil changed reving like that. even when i goto the track i change my oil the next day.
Old Feb 1, 2008 | 05:54 PM
THe Emperor
I forgot to add that this is only like the 3rd day this has happened. Its only after a big snow storm it's not an everyday thing.
Old Feb 1, 2008 | 05:56 PM
drivenCSZ's Avatar
drivenCSZ
do you have snow tires?
if not, you may damage the car when you crash it.
Old Feb 1, 2008 | 06:06 PM
THe Emperor
High performance All season tires and 200 lbs of tube sand. It does fine on the regular streets its just the alley where I have problems. The city doesn't plow the alleys so its like 8 inches of snow in there. But as far as the regular streets the city is on top of it right away they start plowing as salting as soon as the first flake falls you'll never get stuck just the alleys .
Old Feb 1, 2008 | 08:28 PM
KONVERTER's Avatar
KONVERTER
the tires arent really gaining traction so not really wearing on anything...
Old Feb 1, 2008 | 11:59 PM
THe Emperor
So its sorta like revving my engine in neural since the tires spin with no effort?
Old Feb 2, 2008 | 01:01 AM
KONVERTER's Avatar
KONVERTER
well, not really, in neutral, you dont have the flywheel spinning the trans which turning the driveshaft / rear end / rear wheels....
in gear, you are spinning everything...
Old Feb 2, 2008 | 04:12 AM
If it was a good idea it would be recommended regularly in the maintenance schedule.
Every 4,000 miles: Park vehicle in snow. Rock back and forth in first and reverse at 6,000 RPM.
Old Feb 2, 2008 | 05:12 AM
THe Emperor
I never said it was good idea I just wanted to know how bad it is for the car. I'm sure people doing burnouts and donuts isn't the best idea either. Its not like I'm holding the rmp at 5-6k. it'll touch 5-6k for a split second then I'll back off immediately.
Old Feb 2, 2008 | 05:24 AM
Sean's Avatar
Sean
can't you just get a shovel or snow blower?
Old Feb 2, 2008 | 05:26 AM
THe Emperor
Can't exactly shovel the entire alley. I will be getting a second car by next winter though.
Old Feb 2, 2008 | 07:15 AM
Swiffer's Avatar
Swiffer
Can you park somewhere other than the alley?
Old Feb 2, 2008 | 08:26 AM
THe Emperor
Side streets are just as bad almost when it comes to parking. Like I stated earlier its only after a major storm which isn't very often (only 2 this year) so next time its snow packed like that I just drive. I'm just worried if I could have messed anything up by gunning the engine like that even though it was for a very short time. I did take breaks in between the gunning. The whole ordeal only lasted about 10-12 minutes including time I took to shovel some more. Could it be any worse than driving hard at the track? I don't recall the temp gauge moving any higher than normal.
Old Feb 2, 2008 | 03:09 PM
Sean's Avatar
Sean
at the track you have airflow to cool things down.
Old Feb 3, 2008 | 05:58 AM
skn5002's Avatar
skn5002
Shouldn't be hurting anything as long as your not at those rpm's for extended amount of time. Just don't be hitting the rev limiter
Old Feb 3, 2008 | 07:21 AM
THe Emperor
OK thanks. I always made sure that if I did hit 5-6k rpm that it was only for a split second.
