Different Clutch Noise
Old Jul 1, 2004 | 03:03 PM
PAZee's Avatar
PAZee
I have also had the same problem. I took it to the dealer and they couldn't hear anything. I'm beginning to think I am paranoid.
Old Jul 1, 2004 | 04:05 PM
meatwad79's Avatar
meatwad79
n e 1 have the problem where, youre in first, let off the gas still engaged in first, then hear sort of a crackling sound? sounds like your stepping on broken glass alittle??
i get that...
Old Jul 1, 2004 | 04:17 PM
04_CS_Z33's Avatar
04_CS_Z33
I get the exact same noise as the one described in the original post. I have an 04 base model with ~2000 miles on it. It has been happening ever since I got it. I thought that it was normal, I didn't know any better since this is my first car with a manual. I guess I better bring it into the dealer one of these days.
Old Jul 1, 2004 | 05:31 PM
2004 Roadster's Avatar
2004 Roadster
Ditto!
Only happens in first and second gears. I have about 1100 miles, so I am going to wait until first oil change to have them look at it.
Old Jul 2, 2004 | 05:38 AM
Silver04Z's Avatar
Silver04Z
Same problem or is it. I went to the dealer last week and the service tech drove with me. first i drove my car and the clunking was heard. i also have a rattling sound when my car is in neutral and when taking off from 1st gear. the service tech the clunking is normal because the tranny is bouncing to support the pressure of the i dont know drive shaft. he says that they did not use brass but used metal to create the drive shaft. and in that case if the drive shaft would then crack or break during high pressure. he says its the designed of the enginge to do that. he also said the rattling sound is normal. is this a right statement. what do you guys think.
Old Jul 5, 2004 | 07:24 PM
04ECSTAZ's Avatar
04ECSTAZ
i have 6000 miles on my 2004 Z and like many of the others on this post have the EXACT same noise coming from the transmission when you engage/dis-engage the clutch(noticed much easier in a garage) from a stop or starting out in 1st. i work at a Nissan dealership here in Ohio and the car did it since the day i purchased it. My personal belief is that it is the throw-out bearing in the transmission making the noise, just for the simple fact that it immediately fades away when you engage the clutch. i haven't heard any remedies for this problem yet, and there are no T.S.B.(technical service bulletins) on it so far. anyone hear any new updates to this noise yet?
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
