Cause for Computer Speedometer Difference From Dash Speedometer ?
Old Jul 23, 2003 | 02:15 PM
FrankieZZ's Avatar
FrankieZZ
Default Cause for Computer Speedometer Difference From Dash Speedometer ?
Car and Driver just tested the 350Z recently and found a noticable discrepancy between the readings from the analog guage speedometer and the computer digital speedometer ! I have never had this problem on my 350Z ( just the opposite , they couldn't be more synchronized ) and was wondering if anyone has , and if anyone has any thoughts on possible reasons why this could have occurred ?
FrankieZZ
Old Jul 23, 2003 | 02:39 PM
Rizzness's Avatar
Rizzness
Mine appears to be off by .5-1mph: Like the needle will read 49 but the analog says 50.
No clue why. Its at all speeds.
I dunno
Rizz
Old Jul 24, 2003 | 04:33 AM
FrankieZZ's Avatar
FrankieZZ
Does the Z have a wheel sensor to calculate speed for the computer digital readout or is it mechanical ?
FrankieZZ
Old Jul 24, 2003 | 10:38 AM
ares's Avatar
ares
Veteran
all info comes from the tranny. Id imagine its a slight calibration issue with the actual mechanism of the needle. mine is also off by like .5 or 1, but then again, hard to say since the speedometer only has lines like every 5mph. unless it was off by like 3 or 4, I really cant notice.
Old Jul 24, 2003 | 06:07 PM
neohalo1's Avatar
neohalo1
Default same here
Mine is off a bit as well, funny you mentioned this because I was just really noticing it the past few days. I find myself using the digital speedo much more than the analog. Anyone else use one more than the other?
Old Jul 26, 2003 | 04:37 PM
FrankieZZ's Avatar
FrankieZZ
Thanks for the info . Yeh , I use the digital more now and believe it or not , the two match exactly ! Thanks again .
Frank
Old Jul 31, 2003 | 08:38 PM
zgadgetdr's Avatar
zgadgetdr
Default Speedometer calibration
What issue of Car and Driver discussed the speedometer problem with the analog and digital? Thanks.
Old Aug 1, 2003 | 02:54 AM
FrankieZZ's Avatar
FrankieZZ
It was in the July issue if I remember right .
Old Aug 1, 2003 | 05:42 PM
fresno350's Avatar
fresno350
Default digital!
i always use the digital spedo. easier to glance and see when you are driving.
Old Aug 1, 2003 | 08:16 PM
zgadgetdr's Avatar
zgadgetdr
Anyone have their 350Z speedometer calibrated and found a difference between actual speed and reading?
Old Aug 1, 2003 | 08:47 PM
Riceboy369's Avatar
Riceboy369
Default Can this be fixed?
Having the same problem here. Mines off by 1 mph at all speeds. Is there any way to fix this? Maybe take it into the dealer and they should be fixing this (if they can) at no cost right?
Old Aug 1, 2003 | 09:57 PM
zgadgetdr's Avatar
zgadgetdr
Which way was it off?
1. Speedometer reads higher than actual speed, or:
2. Speedometer reads lower than actual speed?
Thanks.
Old Aug 2, 2003 | 03:37 AM
kgatesman's Avatar
kgatesman
My speedometers both read the same speed
Old Aug 2, 2003 | 07:27 AM
Riceboy369's Avatar
Riceboy369
Default Speedometer
The digital is reading 1 mph higher than the analog needle. Ive been thinking about taking it into the dealer and see'ing what they could do.
hulkout
Tuning
Sep 30, 2015 12:33 PM
