some questions (and yeah i did search) about my new Z...
I just got my white 6 speed enthusiast last nite, and this is my first manual car so on the 2 hour drive bakc i stalled it a few timers tryin to get it in first from stop...but im getting better....here are some questions
1.My car is the 18660 made, should i expect less probs being it was made in May/03?
2.Window streak, how obvious is this because i dont see much of a streak right now?
3.ALIGNMENT, should i ask the service dept now to check the alignment to prevent tire wear issues even tho i dont kno if the specs are good?
4.Is the stock alarm any good?should i upgrade to better right now?
5.Maybe its just me being its my first manual car but it seems the engagement point on the clutch is very sensitive as in theres not a lot of room for error in the point?
please help me out this forum is great and I have so far learned a lot in only the 2 weeks ive been a member
yes, most tsb's were probably incorporated in production
see above. If you have the streak, you would probably see it after rolling the window up and down 2-3 times
probably fixed too. I don't think the dealer would do it, but most alignment shops will check it for free, align for around $60 and its good preventive maintenance.
alarm is good enough, plus the ecu has theft deterrent built in.
you will get used to it.
Remember that a clutch is designed and built to take some heavy use. You won't break it unless you do something very obviously stupid like rev to redline and slide your foot off the pedal sideways a bunch of times.
I have found that this car is easier to drive hard than it is to drive easy. Stop taking it easy and try for a couple of fast off-the-line starts. You will learn a lot about clutching from this experience.
is a grounding kit in other words a drop?......if it is, how hard is this car to lower...i had a 2000 prelude b4 this and it was a beeatch...also im gonmna need a camber kit too if i drop it?...i would only want a 1" drop or so
https://my350z.com/forum/showthread.php?threadid=11450
no, a grounding kit is not a drop. Its an addition to the factory grounding wires in the engine bay. The theory is that the factory ground is adequate, but bigger wires and more grouding points are better, and in fact, one of the tuner magazines got good dyno gains by installing one. I highly recommend insanemine's kit. Not real expensive, and definitely worth it. btw, at www.350zfrenzy.com , we will soon be having a contest to give away a couple of these kits!
insaneamines grouding kit
Originally posted by cheeves
What stock alarm?
What stock alarm?
Yes, there is an alarm. Try this... Leave your windows rolled DOWN, get out of the car, lock it with the remote.
Now, reach INSIDE and open the door. (Don't Unlock with the key or the remote)...
Be prepared to turn OFF the Honking horn and flashing lights... I THINK there is also a fuel cut off incorporated with this, but I haven't read enough to be certain.
Can I put a better / different alarm on the Z and still use only ONE remote? I mean I wouldn't want to have to use the factory remote to lock / unlock / roll windows down, and an aftermarket one to turn alarm on and off...
My car is 15641. I had 1 long grease streak on my passenger side window. And little droplets on my driver side window. I will be getting my car back from the dealer today. If you get the work done. I would suggest getting it done before you get your windows tinted.
WayneTN
