Spring Face Lift
Thanks! That means a lot. I have been really pushing hard to get it closer to done. I love modifying, and I like the avenue that I have taken with this. I feel like I am offering something fresh and new to a platform that has been through so many builds.
what engine management are you gonna use... obviously not stock since the flexplate is no longer there with the 6mt... or have a custom flywheel made to have the trigger wheel for the VK? questions
what adapter is used to put on the 6MT??? JWT??? or VKmasters??? with a titan flex plate and titan bellhousing you must be planning on useing stock ECM??? how do you plan on getting around no longer using a TCM??? hood clearance with the intake manifold... I found the VK50VL im is alot lower and JWT makes and adapter plate to make such things happen. just asking questions because I am very interested in this swap... but planning on using VK50VL in a Sileighty
Not a lot of progress lately... hopefully have the engine running in the next 2 weeks. The wiring harness is off being made at the moment. That really leaves AC lines ( a must ) figuring out the clutch flywheel situation and headers... then we'll clean up the engine bay and button everything up, cut a huge hole in my hood and call it a day.
No power steering but the belts on with an idler pulley and I will have ac for sure. drive shaft was perfect fitment, I am really happy about that, and the heater core hoses are on.
AC lines are done next is drop the engine one last time clean up the engine bay, spray it black and put everything back together. The headers are tacked, the transmission adapter plate has to be modified so that the crank able sensor, starter, and ring gear all function correctly, and still waiting on the wiring harness to come back this week *crosses finger* I should have a running motor in the next week or two.
I wanna ask you about your roll cage. How did you do it? I was thinking of having my dad build me one (he welds **** all the time, he's built like 5 trailers for his four wheelers, lawn mowers and other stuff).
Well I don't have a roll cage. I have a harness bar. Which attaches my top to straps of my 6 point harness. I would leave a roll cage to the professionals. Look on the classifieds to find a good deal on a new or used one.
do you have any more pics of the harness bar? how did you install it? did you buy online or make it? I was jw because I was thinking about putting in nismo racing seats and doing a 4pt harness.
