CD Player dead?
Old Oct 4, 2003 | 07:22 PM
KONVERTER's Avatar
KONVERTER
Default CD Player dead?
I was in LA for acouple of days 2 weeks ago and picked up my friend from chicago (who has a z) and he went to put a CD in my cd player...
he hit the eject button and it wouldnt eject my cd in there... (a real cd not cdr) and now the cd wont come out! or play!
any thoughts on how to fix?
(non bose)
Old Oct 4, 2003 | 07:26 PM
alphared's Avatar
alphared
have you tried to disconnect the ground from the battery then reconnect it? it should pop the cd out when its reconnected.
Old Oct 4, 2003 | 07:28 PM
KONVERTER's Avatar
KONVERTER
well, ill try that but doubtfull that will work..
if i hit eject you hear it trying to eject... and if you hit CD when listning to AM... it does nothing...
Old Oct 4, 2003 | 07:44 PM
cckleung's Avatar
cckleung
Keep us updated on how you finally eject the CD
Old Oct 4, 2003 | 07:50 PM
KONVERTER's Avatar
KONVERTER
oh i will! I want the cd out! it was the left side of NIN - Fragile!
grrrrrrrrrrrr...
im going to the dealer on tuesday for an oil change... so ill see what they can do about fixing that...
Old Oct 4, 2003 | 09:12 PM
ares's Avatar
ares
Veteran
Ive heard this problem before actually.
sadly I cant remember the solution, it was easy tho...
Im gonna say try putting another CD in... even if there are 6 in there, just stick another one in(use a blank CD-R of possible just to be safe)
that should do it, it seems it sometimes gets jammed. I personally havent had the problem, but then again, I got the car a year ago, put 6 CDs in and have never taken them out since... so of course I havent had the problem.
could try a search, as I know it was discussed, no clue what to look for tho.
Old Oct 4, 2003 | 09:14 PM
KONVERTER's Avatar
KONVERTER
ive tried wedging another cd in there under the cd taht is in there and pulling it out but that didnt work...
i dont have tweezers or id be tryin that...
Old Oct 4, 2003 | 11:50 PM
Vash's Avatar
Vash
I got a 04 Base model, since the 1st CD I put in the CD player, it never come out. When I hit the eject button, I hread it try to eject it, nothing come out. After waiting for 4 weeks(back order parts), finally Nissan dealer replace the CD unit. Of couse they took my CD (not CDr/CDwr)too.
Old Oct 4, 2003 | 11:53 PM
KONVERTER's Avatar
KONVERTER
damn....
im hopeing they didnt charge you????
Old Oct 5, 2003 | 12:14 AM
JeffR116's Avatar
JeffR116
Hey Konverter, I had the same problem with mine. Totally sucked because it was maybe 3 months after I had the car when it happened.
I came up with a pretty simple solution. I dont know if you can get your hands on a small lockpick kit but I just happened to have one (dont ask why) and I used one of the small hook tipped ones and put it in the cd player. I hooked the middle circle of the cd, pulled a little bit and it just popped out. I put another cd in there and everything was still perfect. Like I said I dont know if you have a lockpick kit but that was an extremely easy fix for me.
Lemme know how it goes.
Jeff
Old Oct 5, 2003 | 12:48 AM
KONVERTER's Avatar
KONVERTER
thanks for the advice...
when i get over this flu and get my skinny **** outta bed ill bring my tweezers down there and figure it out...
Old Oct 8, 2003 | 05:27 PM
Vash's Avatar
Vash
Originally posted by KONVERTER
damn....
I paid nothing. It cover by warranty.
bcoffee20
Nov 19, 2015 06:39 PM
Depravity
Oct 1, 2015 04:49 PM
InternetABYSS
Audio Builds
28
Feb 20, 2003 04:34 PM
grutter
Dec 9, 2002 07:39 AM
