what is Nitromethane
Old Aug 10, 2009 | 02:32 PM
wenlipai's Avatar
wenlipai
Default what is Nitromethane
hi does anyone knows what is Nitromethane? is it much better than Nitrous?
Old Aug 10, 2009 | 02:38 PM
iStan's Avatar
iStan
ZR
According to wiki:
As an engine fuel
In a minor application, nitromethane is used as a fuel in racing, particularly drag racing, as well as for rockets and model airplanes and commonly referred to in this context as "nitro" or "top fuel". The oxygen content of nitromethane enables it to burn with much less atmospheric oxygen in comparison to hydrocarbons such as gasoline:
<dl><dd>4CH<sub>3</sub>NO<sub>2</sub> + 3O<sub>2</sub> → 4CO<sub>2</sub> + 6H<sub>2</sub>O + 2N<sub>2</sub></dd></dl> 14.7 kg of air is required to burn one kilogram of gasoline, but only 1.7 kg of air for one kilogram of nitromethane. Since an engine’s cylinder can only contain a limited amount of air on each stroke, 8.7 times more nitromethane than gasoline can be burned in one stroke. Nitromethane, however, has a lower energy density: Gasoline provides about 42–44 MJ/kg whereas nitromethane provides only 11.3 MJ/kg. This analysis indicates that nitromethane generates about 2.3 times the power of gasoline when combined with a given amount of oxygen.
Nitromethane can also be used as a monopropellant, i.e., a fuel that burns without added oxygen. The following equation describes this process:
<dl><dd>4 CH<sub>3</sub>NO<sub>2</sub> → 4 CO + 4 H<sub>2</sub>O + 2 H<sub>2</sub> + 2 N<sub>2</sub></dd></dl> Nitromethane has a laminar combustion velocity of approx. 0.5 m/s, somewhat higher than gasoline, thus making it suitable for high speed engines. It also has a somewhat higher flame temperature of about 2400 °C. The high heat of vaporisation of 0.56 MJ/kg together with the high fuel flow provides significant cooling of the incoming charge (about twice that of methanol), resulting in reasonably low temperatures.
Nitromethane is usually used with rich air/fuel mixtures because it provides power even in the absence of atmospheric oxygen. When rich air/fuel mixtures are used, hydrogen and carbon monoxide are two of the combustion products. These gases often ignite, sometimes spectacularly, as the normally very rich mixtures of the still burning fuel exits the exhaust ports. Very rich mixtures are necessary to reduce the temperature of combustion chamber hot parts in order to control pre-ignition and subsequent detonation. Operational details depend on the particular mixture and engine characteristics.
A small amount of hydrazine blended in nitromethane can increase the power output even further. With nitromethane, hydrazine forms an explosive salt that is again a monopropellant. This unstable mixture poses a severe safety hazard.
In model aircraft and car glow fuel, the primary ingredient is generally methanol with some nitromethane (0% to 65%, but rarely over 30% since nitromethane is expensive compared to methanol) and 10–20% lubricants (usually castor oil and/or synthetic oil). Even moderate amounts of nitromethane tend to increase the power created by the engine (as the limiting factor is often the air intake), making the engine easier to tune (adjust for the proper air/fuel ratio).
Old Aug 10, 2009 | 02:40 PM
Word Sux's Avatar
Word Sux
Old Aug 10, 2009 | 02:44 PM
wenlipai's Avatar
wenlipai
Originally Posted by iStan
According to wiki:
As an engine fuel
thanks!!!
Old Aug 10, 2009 | 02:57 PM
sanford's Avatar
sanford
***** run Nitromethane lol j/k i was on quoting the movie some 1 must have just got through watching fast and furious
Old Aug 10, 2009 | 02:59 PM
Spork's Avatar
Spork
Old Aug 10, 2009 | 03:04 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Well, after a night of refried beans....
Old Aug 10, 2009 | 03:07 PM
350Ricky's Avatar
350Ricky
I like Rice
Nitromethane was in Pheonix's car when he killed Letty
Old Aug 10, 2009 | 05:11 PM
Spork's Avatar
Spork
If A = B, and B = C, then A = C.
Phoenix was a *****.
Old Aug 10, 2009 | 11:38 PM
kensin0429's Avatar
kensin0429
and it leaves burn marks on the ground..not good
Old Aug 11, 2009 | 03:19 AM
*Boose*'s Avatar
*Boose*
You looked under my hood?
Old Aug 11, 2009 | 06:03 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
only pussies run nitro meth
Old Aug 11, 2009 | 06:09 AM
Spork's Avatar
Spork
So clearly, only pussies use nitromethane... and Phoenix was a *****.
Old Aug 11, 2009 | 06:47 AM
350Zenophile's Avatar
350Zenophile
I didn't realize this forum worked like a dictionary?!
Can someone please define the following for me:
1. Purile
2. Bolshevism
Old Aug 11, 2009 | 06:58 AM
trodis's Avatar
trodis
This thread needs to be closed...
athenG
Jul 3, 2008 05:29 PM
sentry65
Jan 23, 2007 02:55 AM
More Power
Apr 24, 2006 08:12 PM
DMONTE
Jan 20, 2003 11:07 AM
