anyone ever add nitromethane with their water injection kit?
Old Jan 19, 2007 | 02:57 PM
sentry65's Avatar
sentry65
the burninator
Default anyone ever add nitromethane with their water injection kit?
seems like an intresting prospective for making a little more power without having to use nitrous
http://en.wikipedia.org/wiki/Nitromethane
Old Jan 19, 2007 | 03:23 PM
JETPILOT's Avatar
JETPILOT
@ $20 a gallon? You'd have to be stupid. Wate and alcohol is much cheaper.
The issue is oxidizer delivery. Not fuel delivery. Fuel is easy to deliver through injectors. Nitrous is an oxidizer. Nitromethane is not.
JET
Old Jan 19, 2007 | 05:26 PM
Nealoc187's Avatar
Nealoc187
I know a few guys who use nitromethane injection.
Old Jan 19, 2007 | 06:57 PM
Quamen's Avatar
Quamen
you can find nitromethane for about $15 a gallon if you look in the right places specifically hobby stores.
Old Jan 20, 2007 | 07:17 AM
Netko350Z's Avatar
Netko350Z
I have a bottle from my R/C car...
Old Jan 20, 2007 | 07:57 AM
HoldThisForMe's Avatar
HoldThisForMe
I used it and it is amazing!!! I used some stuff called nitro booster. It is for hobby RC cars but the stuff works... snowperformance sells something similiar in a smaller amount but very pricey. but gains of up to 50whp is very tempting!! and I can say for sure i definitely felt a difference when i used the nitrobooster vs regular w/m
Old Jan 20, 2007 | 10:42 AM
sentry65's Avatar
sentry65
the burninator
yeah the snow performance bottle was exactly what I was thinking of actually. I wasn't even thinking of putting the whole thing in. Just thinking maybe like 6 parts water, 5 parts methanol, 2 parts nitro or something along those lines.
Where instead of dumping it all in there for 30-50hp for $30 that'll last you 1 gallon worth of WI, I figure just part of it for like 5-8 hp instead and it'll last 6 fill ups seemed somewhat reasonable. $30 can probably last like 3 months or something that way. If I can spend $10 on lunch, I can spend $10 a month for an extra 5-8 hp
http://www.snowperformance.net/product.php?pk=5
Old Jan 22, 2007 | 10:03 AM
tyrone coupe's Avatar
tyrone coupe
Hi.
i have run nitromethane on my astra coupe turbo and the gains are OK
should only be used when cahsing 1 or 2 tenths that may see you move into the 11's or ten's
the problem is if mixed in quantaties more than 15%
ie 15% nitro,50%meth and 35% water the nitro methane could go into suspension and if pure nitro ends up being injected willlead to lean conditions and possibly detonation and engine failure.
Old Jan 22, 2007 | 10:27 AM
Alberto's Avatar
Alberto
Cranky FI Owner
tyrone-How could it go from your motor to suspension (other than blowing a hole in block and spilling more than nitro under your car)?
Old Jan 22, 2007 | 10:52 AM
helldorado's Avatar
helldorado
He means a chemical suspension. The density and bonding properties of the liquids are different, so if there is a large enough quantity, they can separate from the mixed solution and turn into stacked layers of each, like a cake. Think of gasoline floating on water. If that was the case, you could be drawing pure water, methanol or nitromethane depending on your fluid levels.
Old Jan 22, 2007 | 10:54 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
I think he means if the percentage of nitromethane exceeds 15% the liquid itself will be suspended from the rest of the mixture.
edit:Helldorado said it better and before me, oh well..
Old Jan 22, 2007 | 10:57 AM
Alberto's Avatar
Alberto
Cranky FI Owner
LOL-I read that wrong, thanks for clarification guys....
Old Jan 22, 2007 | 10:58 AM
sentry65's Avatar
sentry65
the burninator
yeah it'd be bad to have the nitromethane bunch up and settle or float in the tank, then when the rest of the liquid has run out, pure nitro would be disasterous depending on how heavy the WI sprayer is set
Old Jan 23, 2007 | 02:55 AM
tyrone coupe
Not car suspension man
But if you runnonly meth and Nitro it would not be a problem as they do not have a problem mixing.
Nitro contains twice the number of oxygen molecules than air and the methonol will richen up the mixture so more fuel more air= more power.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
