Automatically Disable VDC / TCS on startup - Total VDC KILL!
Old Oct 30, 2009 | 08:15 AM
KPierson's Avatar
KPierson
Default Automatically Disable VDC / TCS on startup - Total VDC KILL!
KPtechnologies (www.KPtechnologies.com) is gearing up to release a new and improved revision to the very popular SM20 Switch Memory module!
The SM20 will retain it's original great feature - the ONLY smart VDC / TCS controller on the market that ONLY shuts VDC / TCS off if YOU had it off when the car was shut off (hence the Memory name).
In addition to remembering how you left the car, the new and improved SM20 has an AUX output that is toggled by pushing the VDC / TCS button twice quickly! This output can be used to KILL VDC completely by disrupting power to the yaw sensor! This means you can have Total Control of YOUR vehicle and drive with VDC / TCS on, with VDC / TCS off, or with VDC completely eliminated all from the OEM switch!
If you are simply looking for an elegent way to turn any device on and off this module isn't limited to killing the VDC system - the (-) 200mA AUX output can control ANY device that can be controlled with a standard automotive relay!
Best of all, there will be ZERO price increase for the new functionality! The module will remain available for only $39.99 available at http://www.kptechnologies.com/products.php#/4
To utilize the AUX output for Yaw sensor disable or for any other function you will need an A-SPDT relay (or any other standard automotive relay). The KPtechnologies A-SPDT is availble through the KPtechnologies website for only $9.99 and that includes the wiring harness!
The new module should be up on the site in the next few days. If there is enough interest we will run a group buy for the new product (with relay). Please post up if you are intersted in a group buy.
The Group Buy price (module plus relay) would be $32.49 (before shipping) if we can get 20 people to purchase the product!
Old Oct 30, 2009 | 08:30 AM
str8dum1's Avatar
str8dum1
do u have one that kills abs as well but doenst effect brake/abs/slip lights?
what about running without yaw for extended periods. Did you figure out how to avoid the error lights coming on?
Old Oct 30, 2009 | 08:54 AM
KPierson's Avatar
KPierson
When you cut the yaw sensor the lights will still come on - we are basically just faulting the system out.
If you are going to run extended periods of time with the systems disabled you may want to consider taking the lights out if they both you. Because of the highly integrated system there are not many options for control.
Old Oct 30, 2009 | 02:40 PM
dhays's Avatar
dhays
I can see where this would be nice in one situation. About every other autocross event I forget to turn the VDC off for one run. It is really annoying.
Old Oct 30, 2009 | 02:52 PM
Crom's Avatar
Crom
Nice....count me in
Old Oct 31, 2009 | 01:51 AM
bullant47's Avatar
bullant47
Default Group Buy
Im in for a group buy Module+Relay.
Thanks Ken
Old Nov 2, 2009 | 04:55 AM
KPierson's Avatar
KPierson
This module is now available for purchase through our site!
It's the SM20!
Please keep in mind that if you want the AUX feature you will still need to add an A-SPDT relay to your order.
Old Nov 2, 2009 | 05:49 AM
Jonny Boy's Avatar
Jonny Boy
Count me in on the group buy.
loudtoyz
Apr 6, 2023 04:52 AM
lapham3
Oct 7, 2022 03:15 PM
Jambo016
Sep 16, 2016 01:08 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
