Dai Yoshihara's 350Z roadster Time Attack Car
Old Nov 20, 2009 | 06:35 PM
morepower2's Avatar
morepower2
Default Dai Yoshihara's 350Z roadster Time Attack Car
I thought you guys might be interested in one of our new projects
http://www.motoiq.com/MagazineArticl...tack-350Z.aspx
Making a roadster competitive is sorta tough but we are going to give it a crack!
Old Nov 20, 2009 | 07:08 PM
chrisjersey06's Avatar
chrisjersey06
Good read. Wonder why they chose a "true" coilover in the rear though, doesn't SPL's site mention how the seperate spring and shock setup is superior?
Old Nov 20, 2009 | 08:44 PM
morepower2's Avatar
morepower2
In the article we explain why it was done to reduce unsprung weight and overall weight by taking the load off the toe link. This allows a much lighter toe link, an a lighter spring assembly.
The advantages of having the spring separate from the shock are that there is no friction creating side load due to spring kink on the shock shaft which can make the suspension more supple.
With high quality dampers like KW, the issue of sticksion due to side load is greatly reduced due to the large internal bearing aera and the high quality bearings used by KW.
Old Nov 21, 2009 | 07:05 AM
Fletch69z's Avatar
Fletch69z
Looks awesome!
Old Nov 21, 2009 | 07:11 AM
BornSlippyZ's Avatar
BornSlippyZ
Sweet another Z for RTA next year!
Old Nov 22, 2009 | 01:37 PM
D_K's Avatar
D_K
Do they allow turbo kits on NA cars in the street class? The Z's need them in that class. Most cars that make it to the podium in that class are FI .
Old Nov 22, 2009 | 02:52 PM
chrisjersey06
Ah, so I'm confused then...I guess both kinds have their pros and cons? Always wondered why certain coilovers give you the choice of either setup.
I'm not a suspension guru, just referring to the link on SPL's site where they say, "Therefore, for better handling, it is desirable to have the spring in the stock location."
http://splparts.com/main4/parts/Z33/...oiloverFAQ.htm
Old Nov 22, 2009 | 04:38 PM
morepower2's Avatar
morepower2
In street class anything goes, except the cars have to run on tires with a UTOG of 140 or higher, they have to have a full interior, full exhaust, no lexan and the heater has to be in place. You can add a turbo or supercharger. Its a pretty cool class and its dominated by S2000's for the RWD class.
Old Nov 22, 2009 | 04:41 PM
morepower2's Avatar
morepower2
Both have there pros and cons. If you wanted to have the rear springs in the stock location and wanted to hace adjustable ride height and corner balance the rear you have to run SPL's awsome rear arm and a big NASCAR style 4.5" race spring.
The SPL rear arm is the best but its a big billet CNCed part and if you run 4.5" springs, you sizes and rates are limited. There are a lot of posibilites with a 2.5" rear spring, its the most common.
Going to a coil over conversion probably saves 20 lbs or more and all of it is unsprung.
davidm350
Oct 31, 2015 02:28 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
416blueZ
Sep 25, 2015 10:00 AM
