Take THAT Prius!
Old Jan 15, 2010 | 08:23 PM
adamciya350's Avatar
adamciya350
Default Take THAT Prius!
Just payed $54 to fill up the tank after commuting all week...
decided to drive like a grandpa and see if it worked...
Success!!!!!!!!!!
Old Jan 15, 2010 | 08:29 PM
mtjenkins's Avatar
mtjenkins
I wish i could get 32.6 mpg. You must drive all on the fwy.
Old Jan 15, 2010 | 08:36 PM
350z Guy's Avatar
350z Guy
wow!!! i only get 25 with my car
ahahaha, you probably shift pretty early lol
Old Jan 15, 2010 | 08:37 PM
Valkyrie's Avatar
Valkyrie
probably coasted down a hill with the clutch in and took a picture like a little b!tch.
Old Jan 15, 2010 | 08:38 PM
PDX_Racer's Avatar
PDX_Racer
32+ MPG at an average of 36 MPH. Sounds like a lot of 40-55 MPH in 6th gear.
(The best I've ever seen on the flat is 36.8 in 6th gear at 55 MPH).
Old Jan 15, 2010 | 08:55 PM
drivessidewayz's Avatar
drivessidewayz
This is a common misconception. By shifting early you are not using the car's power band and therefore may be burning more fuel than you need to in order to accelerate to cruising speed.
"Fuel efficiency varies with the vehicle, but generally acceleration is most efficient at 75% to 100% throttle openings.[16] Fuel efficiency during acceleration generally improves as RPM increase until peak torque."
This is as well. Coasting in neutral or with the clutch in actually burns *more* fuel than coasting and leaving it in any gear.
"When coasting with the engine running and manual transmission in neutral, or clutch depressed, there will still be some fuel consumption due to the engine needing to maintain idle speed. While coasting with the engine running and the transmission in gear, most cars' engine control unit with fuel injection will cut off fuel supply, and the engine will continue running, being driven by the wheels."
http://en.wikipedia.org/wiki/Fuel_ec...zing_behaviors
Old Jan 15, 2010 | 09:13 PM
mtjenkins's Avatar
mtjenkins
Both of those are interesting points...
Old Jan 15, 2010 | 09:32 PM
adamciya350
Honestly..I just accelerated slow as hell and didn't pass 3k rpms..no one was on the road lol
Old Jan 15, 2010 | 09:51 PM
michaeljr6's Avatar
michaeljr6
prius gets like 50+mpg
Old Jan 15, 2010 | 10:00 PM
drivessidewayz
Yea, but he had a better one ^^
/thread ?
lol
No doubt the Z is a really nice car with decent fuel economy, but nowhere near a Prius.
Old Jan 15, 2010 | 10:27 PM
kidred350z's Avatar
kidred350z
never talk crap bout prius my friendh ad to rent 1 when his m3 got wrecked and we said it sucked but his tank went 723 miles before having to be filled..
thats nuts.. mine is like 285 lol miles
Old Jan 16, 2010 | 02:17 AM
duro78's Avatar
duro78
I wouldnt put too much trust in that gauge either
Old Jan 16, 2010 | 05:23 AM
F34RL355's Avatar
F34RL355
^+1
Old Jan 16, 2010 | 05:47 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Aren't most people in Miami just a bunch of old farts anyway? When I've been there, traffic was usually bad.
Old Jan 16, 2010 | 06:22 AM
Valkyrie's Avatar
Valkyrie
So if I'm going down a steep hill. You're saying with it in gear and the engine running at 3k rpm is more fuel efficient than putting the clutch in and coasting down at ~1k rpm?
Old Jan 16, 2010 | 06:28 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^yes, because the wheels spin the motor. throw an a/f gauge on there and watch it peg to full lean when you coast in gear which means no fuel is being used.
If you really want to see great mpgs on that gauge just swap in some 1000cc injectors and tune a piggyback/standalone.
Old Jan 16, 2010 | 06:33 AM
PerfZ's Avatar
PerfZ
You can pretty much trick that gauge into about any number you want over a short period. And at that average speed, you obviously were not traveling in the city. Don't think anyone is gong to get anything close to that on an entire tank, even on the highway, cruise set to 55
Old Jan 16, 2010 | 07:25 AM
Zivman's Avatar
Zivman
Success!!!!!!!!!!
did you actually calc it out or only relying on the computer data? I have had my Z long enough to know that computer isn't even close to true MPG
Old Jan 16, 2010 | 08:12 AM
adamciya350
I know...it'd like to believe it is though lol..
Old Jan 16, 2010 | 08:54 AM
barclayloftus's Avatar
barclayloftus
For the last 2-3 months, I was only taking my Z a mile back and forth to the train station (yes i should have walked), and would let her warm up for a good 5 minutes or so before leaving.
Between never getting out of 3rd gear and my heavy foot, I just looked at the MPG computer.
8.2mpg.
Awesome.
