04's pulling to the right?
Old Oct 24, 2003 | 06:26 AM
wakaZ's Avatar
wakaZ
Default 04's pulling to the right?
Was wondering if they were many 04's with alignment issues/tire problems. I saw most were from 03's, and was reading about it in some of the 04 Maxima forums.
Old Oct 24, 2003 | 06:50 AM
350ZnTN's Avatar
350ZnTN
Yes, mine was pulling to the right when I drove it off the lot. I took it in and had them check, sure enough it was off pretty bad. When they did the alignment, it had less than 300 miles on it. It is better, but still pulls to the right a bit.
Old Oct 24, 2003 | 06:52 AM
mxpx_8's Avatar
mxpx_8
My car pulls slightly to the right.
Old Oct 24, 2003 | 08:21 AM
2004z's Avatar
2004z
Sleeps in 350Z
I have an 04 any my car pulls to the right just a tiny bit, it's almost unnoticable. Actually, I don't think I would have even noticed it, but after reading about the same problem with 03's, it's something that I've made sure to keep an eye on.
I don't see this as a problem yet(*crosses fingers*), almost every car I've had pulled in one direction or another at least slightly.
Old Oct 24, 2003 | 02:01 PM
samw1978's Avatar
samw1978
mine pulls slightly to the right, but hard to notice...
Old Oct 24, 2003 | 03:13 PM
EL Diablo's Avatar
EL Diablo
nope. so far so good. I have no issues with my Z. But I only have 500 miles on it. it might be to soon to tell. I'll keep everyone posted as I put on more miles.
Old Oct 24, 2003 | 03:40 PM
keiffer953's Avatar
keiffer953
I just got mine back from the dealer today(they had it for 3 days and gave me a loaner) They replaced the Compression rod swapped tires( not replaced) and then scratched my rims and had to repaint them. So far so good. Oh I have 4000 miles on her.
wakaZ's Avatar
wakaZ
Thanks guys, just noticed that mine is also having a slight pull to the right...bummers.
Old Oct 24, 2003 | 03:53 PM
Ralphus's Avatar
Ralphus
All cars pull slightly to the right in the US.
jor8888's Avatar
jor8888
2004 base , a little to the right.
Old Oct 24, 2003 | 04:50 PM
rands's Avatar
rands
my 04 does not pull in any direction, but the tire pressure guage indicates that the right front tire has a little higher pressure than all the others. i wonder if it will pull right once i equalize the pressure.
Old Oct 24, 2003 | 05:12 PM
jreiter's Avatar
jreiter
I think what Ralphus is referring to is that roads are often crowned, meaning they are slightly higher in the center of the road than at the edges. This allows better water run-off and such during heavy rains. However, this crowning tends to make your car pull to the outside of the road.
A way to test if it's your car or the road is to cross over and drive on the other side of the road. Your car should pull slight to the left at that point. Obviously you should be very careful when doing this, as you'll be on the wrong side of the road.
Old Oct 24, 2003 | 06:08 PM
Dissident's Avatar
Dissident
No problems here. Straight as an arrow at 100+
Old Oct 24, 2003 | 06:12 PM
Dissolved's Avatar
Dissolved
This is BS. Nissan should of corrected these problems with the '04s. No excuse
Old Oct 24, 2003 | 07:08 PM
kbomb's Avatar
kbomb
Mine does pull to the right as well.
I just read in November Road and Track Long-Term Test for 350z.
They had the same pulling right issue and an alignment didn't help. They had to replace the right front compression rod and it was covered by warranty...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
